查看: 2020|回复: 5
[求助]面域填充
发表于 2009-6-9 20:48:00 | 显示全部楼层 |阅读模式
请问大家怎样直接将选中的面域进行填充?
一般的填充是根据坐标点。我不想再取面域的坐标点,直接根据选择的面域填充
发表于 2009-6-9 21:19:00 | 显示全部楼层
填充是根据坐标点?
面域炸开,然后加入Hatch的边界
 楼主| 发表于 2009-6-14 16:29:00 | 显示全部楼层
谢谢!问题解决了
发表于 2009-6-14 22:59:00 | 显示全部楼层
面域不可以直接添加边界吗?为什么要炸开呢?
object.AppendOuterLoop loop
Object
MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_hatch_object.htm">Hatch
The object or objects this method applies to.
Loop
Object (array of objects); input-only
An array of objects forming a closed boundary. The array can consist of one or more objects. If more than one object is used, their endpoints must coincide for the loop to be created properly. The loop may contain the following types of objects: MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_line_object.htm">Line, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_polyline_object.htm">Polyline, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_circle_object.htm">Circle, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_ellipse_object.htm">Ellipse, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_spline_object.htm">Spline, MSITStore:C:\Program%20Files\AutoCAD%202008\help\acadauto.chm::/idh_region_object.htm">Region
发表于 2009-6-14 23:25:00 | 显示全部楼层
哦,疏忽了:)
以前做块内按点填充就是直接用面域做边界的,
好长时间没用忘掉了:)
发表于 2011-6-15 10:47:03 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-5-25 23:24 , Processed in 0.184805 second(s), 23 queries , Gzip On.
