查看: 1976|回复: 6
[原创]open的LSP程序
发表于 2009-6-10 16:32:00 | 显示全部楼层 |阅读模式
(defun c:ww()
(vl-load-com)
(setq kk (getfiled "Select  File" (strcat(vla-get-path (vla-get-activedocument (vlax-get-acad-object))))  "dwg" 16))
(sopen  kk)
(defun openRO (fna)
  (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fna :VLAX-TRUE))
(defun sopen (fna / n)
  (if (= 0 (getvar "SDI"))
    (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fna))
      (if (not (equal 2 (logand 2 (getvar "qaflags"))))
        (setvar "qaflags" (+ (getvar "qaflags") 2))
      (if (not (equal 4 (logand 4 (getvar "qaflags"))))
       (setvar "qaflags" (+ (getvar "qaflags") 4))
      (command "_.open")
      (if (not (equal 0 (getvar "dbmod")))
        (command "_y")
      (command fna)
      (setq n 0)
      (while (and (< n 4)
                  (wcmatch (getvar "cmdnames") "*OPEN*")
          (T
            (command "")
        (setq n (+ n 1))
      (setvar "qaflags" 0)
 楼主| 发表于 2009-6-10 16:59:00 | 显示全部楼层
改成(setq kk (getfiled "Select  File" (strcat(vla-get-path (vla-get-activedocument (vlax-get-acad-object))))  "dwg;dws;dxf;dwt" 16))
就和CAD本身的open开启的选项一样了!
发表于 2009-6-10 20:04:00 | 显示全部楼层
直接用“open”命令不可以吗,
发表于 2009-6-10 22:17:00 | 显示全部楼层
能不能做个“只读”打开文件的功能 ?!
发表于 2009-6-11 08:46:00 | 显示全部楼层
LZ,能不能做个新建(QNEW)命令的LISP程序?好像QNEW命令和OPEN命令一样不能直接调用的,学习学习VLA的用法。
发表于 2011-4-18 03:07:00 | 显示全部楼层
可以应用到程序中,谢谢啦
GMT+8, 2025-3-12 10:29 , Processed in 0.168915 second(s), 24 queries , Gzip On.
