查看: 1999|回复: 7
[求助]如何判断PLine线“开口”、“闭合”
发表于 2009-6-13 16:03:00 | 显示全部楼层 |阅读模式
如何判断PLine线“开口”、“封闭”
实现下图的定义!
发表于 2009-6-13 16:07:00 | 显示全部楼层
vlax-curve-isClosed
发表于 2009-6-13 16:34:00 | 显示全部楼层
dxf组码
70  Polyline flag (bit-coded); default is 0:
1 = Closed; 128 = Plinegen
 楼主| 发表于 2009-6-13 18:46:00 | 显示全部楼层
采用vlax-curve-isClosed函数时
判断上图中第三种(键入“C”)为闭合的pline!
其他均为开口的pline!!
发表于 2009-6-13 19:28:00 | 显示全部楼层
不能确定时再判断第一点与最后一点是否重合
发表于 2009-6-13 21:36:00 | 显示全部楼层
defun isclosed (poly) ; 判断多义线是否闭合
(= 1 (logand 1 (cdr (assoc 70 (entget poly)))))
 楼主| 发表于 2009-6-14 11:12:00 | 显示全部楼层
(defun C:CJ (/ plines bnt count kk)
  (setq plines (ssget (prompt "\n选择多义线:")))
  (setq count 0)
  (while (< count (sslength plines))
    (setq bnt (entget (ssname plines count)))
    (setq kk (isclosed (ssname plines count)) )
    (if  kk
    (command "chprop" (ssname plines count) "" "c" "red" "")
    (vla-put-closed (ssname plines count) 1)
    (setq count (+ 1 count)))
(defun isclosed (poly) ; 判断多义线是否闭合
(or (= 1 (CDR (ASSOC 70 (entget poly))))
(< (distance (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly)) 0.1)
发表于 2009-7-4 14:22:00 | 显示全部楼层
如果能先判断多义线是否闭合
不是闭合的 改成闭合就好啦
GMT+8, 2025-9-22 11:29 , Processed in 0.679336 second(s), 26 queries , Gzip On.
