查看: 1290|回复: 1
[求助]求自动区分圆的大小并标识的LISP程序!
发表于 2009-6-26 21:54:00 | 显示全部楼层 |阅读模式
各位好,大家有没有这样一个LISP程序,就是模板上有很多孔,然后框选模板,模板上一样的孔就会自己标出字母来区分不同的孔,如直径5的用A表示,直径8的用B来表示等,谢谢!
发表于 2009-7-17 15:45:00 | 显示全部楼层
转发:::
;;钻孔圆分类标注.
(defun c:ttt(/ ALIST CENPT ENTDATA1 ENTNAME1 FUZ I J N R SS1)
 (setq aList '((5.0 "A") (8.0 "B") (12.0 "C")));用户自己根据需要定义半径.
 (setq fuz 0.00001)
 (prompt "\n【提示】选择圆对象....")
 (while (not (setq SS1 (ssget '((0 . "CIRCLE"))))))
 (ayOSMode nil);关闭捕捉.
 (setq i 0)
 (while (< i (sslength SS1))
  (setq entName1 (ssname SS1 i))
  (setq entData1 (entget entName1))
  (setq cenPt (cdr (assoc 10 entData1)))
  (setq R (cdr (assoc 40 entData1)))
  (setq j 0)
  (while (< j (length aList))
   (setq n (nth j aList))
   (if (equal R (car n) fuz)
     (vl-cmdf "-Text" "J" "MC" cenPt "" 0.0 (cadr n))
     (setq j (length aList))
    );end_progn
   );end_if
   (setq j (+ j 1))
  );end_while j
  (setq i (+ i 1))
 );end_while i
 (ayOSMode T);打开捕捉.
);end_defun
;;; No.0 对象捕捉开关 函数
(defun ayOSMode (isOpenSnap)
 (if isOpenSnap
  (setvar "osmode" (rem (getvar "osmode") 16384));打开捕捉.
  (setvar "osmode" (+ (rem (getvar "osmode") 16384) 16384));关闭捕捉.
 );end_if
);end_defun
GMT+8, 2025-2-24 14:42 , Processed in 0.291823 second(s), 26 queries , Gzip On.
