查看: 1412|回复: 2
谁能帮改该程序使其有鼠标右键重复+功能
发表于 2009-6-27 08:34:00 | 显示全部楼层 |阅读模式
谁能帮改该程序使其有鼠标右键重复+功能就是按一次“+”,其他重复计算可用鼠标右键重复。
(defun C:+ (/ ns s n i e eb ds i ss pt bool th blio cmdo)
(setq blio (getvar "blipmode"))
(setq cmdo (getvar "cmdecho"))
(setvar "blipmode" 0)
(setvar "cmdecho" 0)
(setq bool "T")
(princ "\nPlease choose numbers:")
(setq ns (ssget))
(if ns
(setq s 0.0)
(setq i 0)
(setq n (sslength ns))
(while (< i n)
(setq e (ssname ns i))
(setq eb (entget e))
(if (= "TEXT" (cdr (assoc 0 eb)))
(if bool
(setq th (cdr (assoc 40 eb)))
(setq bool nil)
(setq ds (atof (cdr (assoc 1 eb))))
(setq s (+ s ds))
(setq i (1+ i))
(setq ss (rtos s 2))
(setq pt (getpoint "\nInsert point of result:"))
(command "text" pt th 0 ss)
(setvar "blipmode" blio)
(setvar "cmdecho" cmdo)
发表于 2009-6-27 19:12:00 | 显示全部楼层
说的不清楚,不知道你的需求!!
 楼主| 发表于 2009-6-27 22:52:00 | 显示全部楼层
本程序是个数字相加运算程序,每算一次要按键盘上“+”一次,有无法子改为第一次按“+”,以后象CAD内画线一样(单击鼠标右键可重复调用画线工具),也可右键重复调用“+”命令.
GMT+8, 2025-2-24 17:27 , Processed in 0.149396 second(s), 25 queries , Gzip On.
