查看: 1972|回复: 4
问龙龙仔
发表于 2003-6-18 10:24:00 | 显示全部楼层 |阅读模式
上次你回答我如何获得一个块中圆(sub-entity)的圆心坐标,利用nentselp函数得到一个转换矩阵来求得. 如果我不想交互地在屏幕上选取实体,而用程序自动选择,那怎么得到转换矩阵?谢谢版主!
发表于 2003-6-18 13:05:00 | 显示全部楼层
先设定对象UCS,再用下列函数护取当前UCS转换矩阵
先设定对象UCS<图块>,再用下列函数护取当前UCS转换矩阵
;;;The ucs matrix function
(defun GETACTIVEUCSMATRIX ()
  ;;(vlax-tmatrix
    (M_REV (append
             (mapcar
               '(lambda        (VECTOR)
                  (append (trans VECTOR 1 0 t) '(0.0))
               '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0))
             (list (append (getvar "ucsorg") '(1.0)))
(defun M_REV (A / N U V)
  (setq N 0)
  (repeat (length A)
    (setq U (cons (mapcar '(lambda (V) (nth N V)) A) U)
          N (1+ N)
  (reverse U)
 楼主| 发表于 2003-6-18 15:06:00 | 显示全部楼层
有点不明白
有点不明白,“先设定对象UCS<图块>”是什么意思?怎么和GETACTIVEUCSMATRIX 函数连接?
我不知道我的上次问题说的是否明白?就是你给我的程序:
(defun MCS2WCS (TMX P / WX WY WZ)
  (list
    (setq WX
     (* (car (nth 0 TMX)) (car P))
     (* (cadr (nth 0 TMX)) (cadr P))
     (* (caddr (nth 0 TMX)) (caddr P))
     (cadddr (nth 0 TMX))
    (setq WY
     (* (car (nth 1 TMX)) (car P))
     (* (cadr (nth 1 TMX)) (cadr P))
     (* (caddr (nth 1 TMX)) (caddr P))
     (cadddr (nth 1 TMX))
    (setq WZ
     (* (car (nth 2 TMX)) (car P))
     (* (cadr (nth 2 TMX)) (cadr P))
     (* (caddr (nth 2 TMX)) (caddr P))
     (cadddr (nth 2 TMX))
;;使用例
(defun C:TT (/ WW TMX P)
  (setq WW (nentselp "\n点选图块中的圆"))
  (setq TMX (caddr WW))
  (setq P (cdr (assoc 10 (entget (car WW)))))
  (MCS2WCS TMX P)
中我不想手工去点选圆实体,怎么办?麻烦你.
发表于 2003-6-19 08:02:00 | 显示全部楼层
例子
(defun TT (BNAME / BLKDEF ENT P)
;;;先设定对象UCS<图块>,再用下列函数护取当前UCS转换矩阵
    (M_REV (append
             (mapcar
               '(lambda        (VECTOR)
    (setq N 0)
    (repeat (length A)
            N (1+ N)
    (reverse U)
;;;This is pretty much straight from AutoLISP Programming... by Rawls & Hagen.
;;;tmx: 4x4 transformation matrix from nentselp - (caddr (nentselp))
;;;p: point to transform
    (list
      (setq WX
      (setq WY
      (setq WZ
  (defun DO_IT (/ SS N TMX)
    (setq SS (ssget "x"
                    (list (cons 0 "insert")
                          (cons 2 BNAME)
                          (cons 410 (getvar "CTAB"))
    (command "_.undo" "m")
    (setq N 0)
    (repeat (sslength SS)
      (command "_.ucs" "_ob" (ssname SS N))
      (setq TMX (GETACTIVEUCSMATRIX))
      ;;打印中心坐标(WCS)
      (print (MCS2WCS TMX P))
      (setq N (1+ N))
    (command "_undo" "b")
  (setq        BLKDEF (vla-item (vla-get-blocks
                           (vla-get-activedocument
                             (vlax-get-acad-object)
                         BNAME
;;;取出图块中圆心坐标
;;;假设图块中只有一圆,如附图
  (vlax-for ENT        BLKDEF
    (setq P (cdr (assoc 10 (entget (vlax-vla-object->ename ENT)))))
  (DO_IT)
附圖
 楼主| 发表于 2003-6-19 09:29:00 | 显示全部楼层
谢谢龙版主.
谢谢龙版主,我试成功了;我对没怎么用过VLISP的函数,要明白你的程序看来要花些时间了...谢谢.
GMT+8, 2025-5-16 04:29 , Processed in 0.184766 second(s), 26 queries , Gzip On.
