我回复了
(defun tt(o / i n j)(while (< (1+ (setq i (if (not i) -1 (1+ i)))) (length o))(while (= j (setq j (nth (setq i (1+ i)) o))))(setq n (append n (list j))))(cons (car o) n))
命令: (tt '(a b c c c d c o))(A B C D O)
qjchen发表于2009-7-27 17:48:00:)一写的很烂的代码,你试试看行不,只能1维消重,多维的大概得递归吧(defun test(lst / lst1 i res) (setq lst1 (cons (list (car lst)) lst) i -1) (foreach x lst (setq i
测试结果如下:
(rem-adj2 '(nil nil 1 2 3 3 3 3 32 1 1 1 nil nil))(nil 1 2 3 32 1 nil)
(defun test (lst / a lst2) (while (setq a (car lst) lst2 (cons a lst2) lst (vl-remove a lst))) (reverse lst2) )
(test '(a b c c c d c o))
(a b c d o)
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-10-27 05:17 , Processed in 0.182369 second(s), 27 queries , Gzip On.
