查看: 1661|回复: 1
[求助]点坐标转换
发表于 2009-7-28 11:07:00 | 显示全部楼层 |阅读模式
其实就是在图纸空间的一个视口上(非激活进入)点选一点,如何得到这点在模型空间WCS真实坐标?
trans函数看的不明白,不知道后面的参数应该是几?
发表于 2009-7-28 15:47:00 | 显示全部楼层
Public Sub VPCoords(vp As AcadPViewport, LL, ur)
    Dim min, max, oldMode As Boolean
    vp.GetBoundingBox min, max
    oldMode = ThisDrawing.MSpace
    ThisDrawing.MSpace = True
    LL = ThisDrawing.Utility.TranslateCoordinates(min, acPaperSpaceDCS, acDisplayDCS, False)
    ur = ThisDrawing.Utility.TranslateCoordinates(max, acPaperSpaceDCS, acDisplayDCS, False)
    ThisDrawing.MSpace = oldMode
End Sub
请参照这个
GMT+8, 2025-4-30 19:58 , Processed in 0.183309 second(s), 23 queries , Gzip On.
