查看: 1043|回复: 0
能否将下列程序改为非同目录下运行?
发表于 2009-8-5 21:53:00 | 显示全部楼层 |阅读模式
Dim WS, REG, Path, Key, SubKey, Value, el, flag
Set WS = WScript.CreateObject("WScript.Shell")
Path = WS.CurrentDirectory & "\Load.fas"
Set REG = GetObject("winmgmts:\\.\root\default:StdRegProv")
HKCU = &H80000001
HKLM = &H80000002
Key = "Software\Autodesk\AutoCAD"
REG.GetStringValue HKCU, Key, "CurVer", Value
Key = Key & "\" & Value
SubKey = "\Profiles"
REG.GetStringValue HKCU, Key & SubKey, "", Value
SubKey = SubKey & "\" & Value & "\Dialogs\Appload\Startup"
REG.EnumValues HKCU, Key & SubKey, Item, Value
If IsNull(Item) Then
  REG.CreateKey HKCU, Key & SubKey
  REG.SetStringValue HKCU, Key & SubKey, "", "1"
  REG.SetStringValue HKCU, Key & SubKey, "NumStartup", "1"
  REG.SetStringValue HKCU, Key & SubKey, "1Startup", Path
  SubKey = "\Applications\AcadAppload"
  REG.GetStringValue HKLM, Key & SubKey, "DESCRIPTION", Value
  REG.SetStringValue HKCU, Key & SubKey, "DESCRIPTION", Value
  REG.GetStringValue HKLM, Key & SubKey, "LOADER", Value
  REG.SetStringValue HKCU, Key & SubKey, "LOADER", Value
  REG.GetDWORDValue HKLM, Key & SubKey, "LOADCTRLS", Value
  Value = Value or 2
  REG.SetDWORDValue HKCU, Key & SubKey, "LOADCTRLS", Value
  MsgBox "成功加入自动加载列表!"
Else
  flag = False
  If Not IsNull(Value) Then
    Item = Value & "Startup"
    REG.GetStringValue HKCU, Key & SubKey, Item, Value
    If UCase(Right(Value,9))="\LOAD.FAS" Then flag = True
  End if
  IF flag Then
    MsgBox "TB Tools 已在自动加载列表中!"
  Else
    REG.GetStringValue HKCU, Key & SubKey, "NumStartup", Value
    Value = CStr(CInt(Value)+1)
    REG.SetStringValue HKCU, Key & SubKey, "", Value
    REG.SetStringValue HKCU, Key & SubKey, "NumStartup", Value
    REG.SetStringValue HKCU, Key & SubKey, Item, Path
    REG.GetDWORDValue HKCU, Key & SubKey, "LOADCTRLS", Value
    Value = Value or 2
  End if
End if
该程序为本站下载,想改为非同目录下运行,就是如何做到把(指定加载同目录下的Load.fas文件),改为(指定加载不同目录下的Load.fas文件),即我的*.VBS在D:\AA\kk.VBS,而Load.fas在C:\bb\Load.fas.请高手指导,谢谢!
GMT+8, 2024-11-6 03:05 , Processed in 0.158784 second(s), 25 queries , Gzip On.
