查看: 1678|回复: 4
[求助]VBA这样的选择集怎样写
发表于 2009-8-9 22:19:00 | 显示全部楼层 |阅读模式
直线的起点坐标为10,25,终点的坐标为100,129,图层名为LINE1,画图之前现要判断这条线是否存在,如果存在且图层相同,则不画这条线,如果不存在或存在但图层不是LINE1就画这条线,在直线的两端分别插入两个名称为2的块,图层名为BLOCK1,再在直线两端分别插入两个单行文字“起点”“终点”,画图之前现要判断他们是否存在,块和文字同样要做与直线相同的判断。有那位大哥知道改怎么写吗?
发表于 2009-8-10 00:46:00 | 显示全部楼层
过滤器:pnt1,pnt2先赋值
0,"line",
10,pnt1,
10,pnt2,
8,"line1"
 楼主| 发表于 2009-8-10 03:27:00 | 显示全部楼层
我这样写怎么不行,而且直线都画不出来,问题出在哪里?
Sub lline()
Dim linex As AcadLine
Dim pnt1(2) As Double, pnt2(2) As Double
pnt1(0) = 10:  pnt1(1) = 25:  pnt1(2) = 0
pnt2(0) = 100: pnt2(1) = 129: pnt2(2) = 0
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("temline")
Dim FilterType As Variant, FilterData As Variant
Dim gpCode(3) As Integer, dataValue(3) As Variant
gpCode(0) = 0
dataValue(0) = "LINE"
gpCode(1) = 8
dataValue(1) = "LINE1"
gpCode(2) = 10
dataValue(2) = pnt1
gpCode(3) = 10
dataValue(3) = pnt2
FilterType = gpCode
FilterData = dataValue
sset.Select acSelectionSetAll, FlterType, FilterData
If sset.Count = 0 Then
        Set linex = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
    Else
        MsgBox "该线段已存在"
    End If
End Sub
发表于 2009-8-10 08:34:00 | 显示全部楼层
搞错:),终点DXF码是11
Sub test()
On Error Resume Next
    ThisDrawing.SelectionSets("temline").Delete
    Dim ft(3) As Integer, fd(3) As Variant
    ft(0) = 0: fd(0) = "LINE"
    ft(1) = 8: fd(1) = "LINE1"
    ft(2) = 10: fd(2) = pnt1
    ft(3) = 11: fd(3) = pnt2
    sset.Select acSelectionSetAll, , , ft, fd
        Set linex = ThisDrawing.ModelSpace.AddLine(pnt1, pnt2)
        linex.Layer = "LINE1"
    Else
        MsgBox "该线段已存在"
    End If
End Sub
 楼主| 发表于 2009-8-10 22:19:00 | 显示全部楼层
原来是这样,谢谢指点!
GMT+8, 2025-2-22 05:36 , Processed in 0.154538 second(s), 23 queries , Gzip On.
