查看: 1807|回复: 1
选择集法修改尺寸线的标注比例和图层.
发表于 2009-8-12 12:13:00 | 显示全部楼层 |阅读模式
主程序
Sub DimensionScale()
  Dim sSet As AcadSelectionSet
  Dim tempStr As String, fType, fData
  Set sSet = returnCornerAllSelects()
  Dim objDim As AcadDimension, objD As AcadDimRotated
  Dim Ent As AcadEntity
  For Each Ent In sSet
    If InStr(UCase(Ent.ObjectName), "DIMENSION") > 0 Then
      Set objDim = Ent
        With objDim
          .LinearScaleFactor = 10  '尺寸标注比例
          .Layer = "尺寸线"
        End With
     End If
  Next Ent
End Sub
选择集程序
Function returnCornerAllSelects() As AcadSelectionSet
  Dim Pt1 As Variant, Pt2 As Variant
  With ConnectCad.ActiveDocument
    On Error Resume Next
    Pt1 = .Utility.GetPoint(, "Select First Point")
    Pt2 = .Utility.GetCorner(Pt1, "Select Corner Point")
    Set sSet = .SelectionSets.Item(tempsSet)
    sSet.Delete
    tempsSet = "temp"
    Set sSet = .SelectionSets.Add(tempsSet)
    sSet.Select acSelectionSetCrossing, Pt1, Pt2
  End With
  Set returnCornerAllSelects = sSet
End Function
发表于 2009-8-14 09:54:00 | 显示全部楼层
版主是在放代码啊
GMT+8, 2025-4-30 19:52 , Processed in 0.157514 second(s), 24 queries , Gzip On.
