查看: 2160|回复: 4
关于sengcommand
发表于 2009-8-20 14:37:00 | 显示全部楼层 |阅读模式
            Polyline offsetBox = cutBox.GetOffsetCurves(0.2)[0] as Polyline;
            if (offsetBox.Area < cutBox.Area)
                offsetBox = cutBox.GetOffsetCurves(-0.2)[0] as Polyline;
            Point3d[] p = new Point3d[offsetBox.NumberOfVertices];
            for (int i = 0; i < offsetBox.NumberOfVertices; i++)
                p=new Point3d(offsetBox.GetPoint3dAt(i).X, offsetBox.GetPoint3dAt(i).Y, 0);
            offsetBox.Dispose();
            //裁剪
            acdDoc.SendCommand("TRIM\r");
            acdDoc.SendCommand(cutBox.ObjectId.ToString() + "\r\r");
            for (int i = p.GetLowerBound(0); i <= p.GetUpperBound(0); i++)
                Point3d p1 = p;
                Point3d p2 = new Point3d();
                if (i == p.GetUpperBound(0))
                    p2 = p[0];
                else
                    p2 = p[i + 1];
                acdDoc.SendCommand("f\r");
                acdDoc.SendCommand(p1.X.ToString()+","+p1.Y.ToString() + "\r");
                acdDoc.SendCommand(p2.X.ToString()+","+p2.Y.ToString() + "\r\r");
                //CommandLine.Command("TRIM", cutBox.ObjectId, "", "F", p1, p2, "", "");
            acdDoc.SendCommand("\r");
这段代码中发送坐标会让CAD死机,同样的数据也这样把坐标手工输入就没问题,为什么会这样?
发表于 2009-8-20 15:40:00 | 显示全部楼层
能用代码实现就尽量不要用SendCommand
看看置顶的曲线贴
 楼主| 发表于 2009-8-22 17:42:00 | 显示全部楼层
纠正,经过几天的跟踪调试,发现不是发送坐标引起的,是cutBox.ObjectID.Tostring()这句闹的,谁知道怎么实现向命令行发送实体?
发表于 2009-8-22 18:54:00 | 显示全部楼层
使用曲线类的GetSplitCurves方法可以满足你的要求,不推荐用SendCommand方法
发表于 2009-8-26 10:17:00 | 显示全部楼层
看高手出招
GMT+8, 2025-11-26 15:24 , Processed in 0.200261 second(s), 23 queries , Gzip On.
