查看: 2375|回复: 1
常用材料表格式。
发表于 2009-8-20 21:52:00 | 显示全部楼层 |阅读模式
Sub MaterialTitle()
  Dim cadApp As AcadApplication
  Set cadApp = ConnectCad
  Dim xArr, textTitle, heightTitle, materialRow
  xArr = Array(0, 20, 50, 97, 107, 137, 148.5, 160, 171.5, 180)
  textitle = Array("件  号", "图号或标准号", "名           称", "数量", "材    料", "单", "总", "质 量(kg)", "备   注")
  Dim pp0(2) As Double, pp1(2) As Double
    materialRow = 13
    'heightTitle = 14 + 8 * materialRow
    pp1(0) = 180
  With cadApp.ActiveDocument.ModelSpace
    For ii = 0 To materialRow + 2
      If ii = 0 Then
        heightTitle = 0
      ElseIf ii = 1 Then
        heightTitle = 14
      Else
        heightTitle = heightTitle + 8
      End If
      pp0(1) = heightTitle:
      pp1(1) = pp0(1)
      Set objLine = .AddLine(pp0, pp1)
    Next ii
    Dim p0(2) As Double, p1(2) As Double
    p0(1) = 0: p1(1) = heightTitle
    For jj = 0 To UBound(xArr)
      p0(0) = xArr(jj): p1(0) = p0(0)
      Set objLine = .AddLine(p0, p1)
    Next jj
  End With
End Sub
发表于 2018-11-12 15:21:27 | 显示全部楼层
Set cadApp = Conne   错误要求对象怎么回事
GMT+8, 2025-5-23 07:55 , Processed in 0.158477 second(s), 23 queries , Gzip On.
