查看: 1582|回复: 1
老大!帮忙看看,自己没搞定,arc坐标输出,谢谢了
发表于 2009-8-27 13:07:00 | 显示全部楼层 |阅读模式
Sub test()
     Dim X As Double, y As Double, Z As Double
     Dim n As Long
     n = ThisDrawing.ModelSpace.Count
     Dim Pt As Variant
     Pt = ThisDrawing.Utility.GetPoint(, "指定内部点: ")
     ThisDrawing.SendCommand "_-Boundary" & vbCr & Pt(0) & "," & Pt(1) & vbCr & vbCr
     Dim lwpLineObj As AcadLWPolyline
     If ThisDrawing.ModelSpace.Count > n Then
         Set lwpLineObj = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
         'MsgBox "面积" & Format(lwpLineObj.Area, "0.000") & "平方米"
         'lwpLineObj.Delete
     Else
         MsgBox "未发现有效的边界"
     End If
           Dim i As Long, num As Long
           Dim retCoord As Variant
           num = 0
           retCoord = lwpLineObj.Coordinates
           num = (UBound(retCoord) - LBound(retCoord) + 1) / 2
           For i = 0 To num - 1
            X = retCoord(2 * i + 1)
            y = retCoord(2 * i)
            MsgBox ("X=" & X & "  " & "Y=" & y)
怎么判断是圆弧,并把圆弧的数据读出???????????  谢谢了
           Next i
End Sub
发表于 2009-8-29 16:39:00 | 显示全部楼层
    Dim sset As AcadSelectionSet
    Dim obj As Object
    Dim objarc As AcadArc
    For Each obj In sset
        If TypeOf obj Is AcadArc Then
            Set objarc = obj
        End If
        '获得圆弧的数据
    Next
GMT+8, 2025-5-26 11:51 , Processed in 0.257985 second(s), 24 queries , Gzip On.
