查看: 1559|回复: 3
【***这个LISP该如何写???***】请ZZXXQQ进来
发表于 2009-8-28 22:41:00 | 显示全部楼层 |阅读模式
左侧下拉列表中,用户选择相应的DN数据,右侧,自动跳出不同的数据。
DCL文件如下:
dcl_settings : default_dcl_settings { audit_level = 3; }
AAA : dialog {
    label = "管件连接尺寸汇编查询系统";
    : boxed_column {
        label = "公制";
        mnemonic = "?聡";
        : row {
            : popup_list {
                label = "DN";
                value = "1";
                key = "1";
                mnemonic = "D";
                list = "15\n20\n100";
                tabs = "1";
                action = "1";
                fixed_width = true;
            : column {
                : edit_box {
                    label = "PIPE             ";
                    value = "2";
                    key = "2";
                    mnemonic = "P";
                    action = "2";
                    width = 5;
                    height = 1;
                : edit_box {
                    label = "90°ELBOW";
                    value = "3";
                    key = "3";
                    mnemonic = "9";
                    action = "3";
                : edit_box {
                    label = "45°ELBOW";
                    value = "4";
                    key = "4";
                    mnemonic = "4";
                    action = "4";
                : edit_box {
                    label = "TEE              ";
                    value = "55";
                    key = "5";
                    mnemonic = "T";
                    action = "5";
                : edit_box {
                    label = "REDUCER    ";
                    value = "6";
                    key = "6";
                    mnemonic = "R";
                    action = "6";
    : text {
        label = " ";
    : text {
        label = "               授人以鱼,不如授之以渔!---老子";
    ok_only;
发表于 2009-8-29 14:06:00 | 显示全部楼层
key "1"值保存在一个表中,如:
(setq k1 '("15" "20" ... "100"))
相应key "2"值也保存在一个表中,与key "1"表相对应:
(setq k2 '("50" "60" ... "108"))
同理:
(setq k2 '("67" "80" ... "150"))
当key "1"活动时,用一个函数读出当前key "1"值(注意:该值是顺序号,要用ITOA转成数字使用),并设key "2"到key "6"的值。
(action_tile "1" "(chdata)")
(defun chdata ()
 (setq i (itoa (get_tile "1")))
 (set_tile "2" (nth i k2))
 (set_tile "6" (nth i k6))
 楼主| 发表于 2009-12-7 15:13:00 | 显示全部楼层
如果是要满足2个或者更多条件的该如何写啊,如图
发表于 2009-12-10 20:51:00 | 显示全部楼层
用多维表就能解决。例如:
   (10 (2.5 (75 50 11 10 4))(6 (90 60 14 12 4))(16 (120 78 14 16 8)))
   (12 (……))
GMT+8, 2025-2-23 10:53 , Processed in 0.181644 second(s), 26 queries , Gzip On.
