查看: 2082|回复: 4
选择集的and和or的应用.
发表于 2009-8-29 17:27:00 | 显示全部楼层 |阅读模式
这种组合,实现只在"AA1"图层中,找line实体.
 fType(0) = -4: fData(0) = "<And"
    fType(2) = 0: fData(2) = "text"
    fType(1) = 8: fData(1) = "AA1"
    fType(3) = -4: fData(3) = "And>"
Sub l()
  Dim sSet As AcadSelectionSet
  Dim fType(3) As Integer, fData(3) As Variant
  Dim sSetName As String
  sSetName = "First"
  With ThisDrawing
      On Error Resume Next
      If Not IsNull(.SelectionSets.Item(sSetName)) Then
        Set sSet = .SelectionSets.Item(sSetName)
        sSet.Delete
      End If
      Set sSet = .SelectionSets.Add(sSetName)
    fType(1) = 8: fData(1) = "标题栏"
    sSet.Select 5, , , fType, fData
    sSet.Highlight True
    'Debug.Print sSet.Count
  End With
End Sub
'''这种组合是图层aa1中的line和text实体
    fType(0) = -4: fData(0) = "<Or"
    fType(2) = -4: fData(2) = "Or>"
    fType(3) = -4: fData(3) = "<Or"
    fType(4) = 0: fData(4) = "Line"
    fType(5) = 0: fData(5) = "Text"
Sub ls()
  Dim fType(6) As Integer, fData(6) As Variant
  sSetName = "First"
  With ThisDrawing
        sSet.Delete
      End If
    fType(6) = -4: fData(6) = "Or>"
    sSet.Highlight True
  End With
End Sub
发表于 2009-8-29 19:04:00 | 显示全部楼层
and在or内部才有用
选择集默认为and(与)
-》等效于
    fType(0) = 8: fData(0) = "标题栏"
    fType(1) = 0: fData(1) = "text"
发表于 2009-8-29 19:07:00 | 显示全部楼层
正确的写法:
8,"AA1",0,"Line,Text"
发表于 2010-1-6 17:28:00 | 显示全部楼层
谢谢啦
发表于 2010-2-1 23:15:00 | 显示全部楼层
必须得用运算符前后夹住图层AA1,是这个意思吗
GMT+8, 2026-1-18 04:15 , Processed in 0.150300 second(s), 24 queries , Gzip On.
