查看: 2291|回复: 2
Viewport指的是什么物理性质
发表于 2009-8-31 21:45:00 | 显示全部楼层 |阅读模式
Viewport指的是什么物理性质
发表于 2009-8-31 21:58:00 | 显示全部楼层
Viewport - 视口
View - 视图
你要的是这个?
To change the view within a Viewport object, you manipulate the view of a viewport you use its member properties. The following member properties allow you to adjust the display of the view in a viewport:
ViewCenter - Specifies the view center of the view in the viewport.
ViewDirection - Specifies the vector from the target to the camera of the view in the viewport.
ViewHeight - Specifies the height of the Model Space view within the viewport.
ViewTarget - Specifies the location of the target of the view in the viewport.
 楼主| 发表于 2009-9-1 07:28:00 | 显示全部楼层
指的是什么窗口吧
GMT+8, 2025-11-26 15:18 , Processed in 0.186548 second(s), 23 queries , Gzip On.
