帖子
查看: 2833|回复: 6
[求助]求从多段线偏移某个线条的lisp程序?
发表于 2009-9-3 19:07:00 | 显示全部楼层 |阅读模式
大家好,从某个封闭多段线偏移一个直线,一般我会把当前的封闭多段线炸开,然后选一直线偏移,能不能不用炸开就直接选一条直线偏移,这样就能节约很多时间,求这种功能的lisp,谢谢!
发表于 2009-9-4 20:39:00 | 显示全部楼层
;; 多段线逐段双向偏移
(defun c:test823 ()
  (CMDLA0)
  (xyp-MkLaCo "TEST" 1)
  (SETQ DIST (UDIST 1 "" "距离<输入或鼠标直接量取>" DIST nil))
  (while (setq e (entsel "\n多段线: "))
    (if (member (xyp-get-dxf 0 (car e)) '("POLYLINE" "LWPOLYLINE"))
 (setq a  (xyp-get-Pts&te e)
       p1 (car a)
       p2 (cadr a)
       S2 (XYP-ADD-LINE P1 P2)
 (xyp-Offset (entlast) dist t t t)
  (CMDLA1)
 楼主| 发表于 2009-9-6 18:53:00 | 显示全部楼层
谢谢版主回复,有没有单向偏移的啊要,双向的用得很少,呵呵!
 楼主| 发表于 2009-9-8 19:07:00 | 显示全部楼层
版主,我用后出现错误的提示:
命令: TEST823 ; 错误: no function definition: CMDLA0
怎么回事啊要,谢谢!
发表于 2011-8-28 13:43:06 | 显示全部楼层
这个功能外挂有的。PRESSCAD
发表于 2011-9-6 15:00:45 | 显示全部楼层
;;;;单段偏移
(defun c:oo (/ od ss_1 s1 s3 s2 sa sa1 ssK3 e)
  (Setvar "cmdecho" 0)
  (command "_undo" "g")
  (setq od (getvar 'offsetdist))
  (princ "\n 请输入偏移复制距离<")
  (princ od)
  (princ ">")
  (setq od (getreal))
  (if od
    (setvar 'offsetdist od)
  (prompt "\n 请选择要偏移复制的图元")
  (SETQ ss_1 NIL)
  (WHILE (null ss_1)
    (setq ss_1 (entsel))
  (SETQ S1 (CaR SS_1))
  (redraw s1 3)
  (prompt "\n 请选择偏移复制方向")
  (setq s3 (getpoint))
  (IF (= (cdr (assoc 0 (entget s1))) "LWPOLYLINE")
    (PROGN
      (setq s2 (CAR (cdr ss_1)))
      (setq sa (entlast))
      (command "_explode" s1)
      (setq sa1 (ssnamex (ssget s2)))
      (setq ssk3 (ssadd))
      (setq e (entnext sa))
      (ssadd e ssk3)
      (while e
        (setq e (entnext e))
        (if e
          (ssadd e ssk3)
      (SETQ s1 (nth 1 (car sa1)))
      (command "_offset" "" s1 s3 "")
      (command "_pedit" s1 "" "j" ssk3 "")
  (command)
  (command "_undo" "e")
发表于 2012-5-8 19:13:03 | 显示全部楼层
哇强大呀 好东西收下了
GMT+8, 2025-4-14 16:35 , Processed in 0.205476 second(s), 24 queries , Gzip On.
