查看: 2624|回复: 1
请版主指导一下我这段代码,将实体前置、后置均无效果,即无反应。
发表于 2009-9-7 17:42:00 | 显示全部楼层 |阅读模式
        [CommandMethod("g")]//让光栅自动置前置后无反应
        public static void g()
            BlockTableRecord 块表记录;
            DrawOrderTable dot;
            ObjectIdCollection oo;
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            Editor ed = acDoc.Editor;
            PromptSelectionOptions rp = new PromptSelectionOptions();
            rp.MessageForAdding = "请选择光栅";
            PromptSelectionResult res = acDoc.Editor.GetSelection(rp);
            if (res.Status == PromptStatus.OK)
                SelectionSet acSSet = res.Value;
                using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    BlockTable 块表 = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                    块表记录 = acTrans.GetObject(块表["*Model_Space"], OpenMode.ForRead) as BlockTableRecord;
                    dot = (DrawOrderTable)acTrans.GetObject(块表记录.DrawOrderTableId, OpenMode.ForWrite, false);
                    oo = Ldyh.LdyhAutoCAD.Tools.CollectBlockEnts(块表记录);
                    dot.MoveBelow(oo, acSSet[0].ObjectId);
                    acTrans.Commit();
用MoveToTop、MoveToBottom、MoveBelow、MoveBelow均无反应,
但手工在AutoCAD中操作是可以的,操作顺序是:选择光栅-右键菜单-绘图次序-后置。这样,其它实体都浮在了光栅表面上,即不再被光栅所覆盖了。
发表于 2009-9-7 17:59:00 | 显示全部楼层
看下VBA的帮助http://www.mjtd.com/object/acad2004/ex_SortentsTable.htm
或者你应该下载ObjectArx2010 sdk,里面有函数的用法说明
Public
		Function
		MoveToTop(
    collection
		As ObjectIdCollection
) As void
Places all the entities specified in the input object ID array at the ending of the draw order. The entities being moved retain their relative draw order.
这里似乎文档有点问题:)
GMT+8, 2025-11-26 15:27 , Processed in 0.191908 second(s), 23 queries , Gzip On.
