查看: 2810|回复: 3
求两条直线的交点
发表于 2009-9-11 12:05:00 | 显示全部楼层 |阅读模式
在图上任意做两条相交直线
  1. Sub ll()
  2.   Dim Ent As AcadEntity
  3.   Dim objLine(1) As AcadLine
  4.   Dim Pp, Pp1, Pt1, Pt2
  5.   With ThisDrawing
  6.     ii = 0
  7.     For Each Ent In .ModelSpace
  8.       Set objLine(ii) = Ent
  9.       With objLine(ii)
  10.         For jj = 0 To 2
  11.           Select Case ii
  12.             Case 0
  13.               Pt1 = .StartPoint
  14.               Kk1 = .Delta(1) / .Delta(0)
  15.               .color = 1
  16.               yy = Kk1 * (.EndPoint(0) - .StartPoint(0)) + .StartPoint(1)
  17.
  18.               'Debug.Print "yy", yy, .EndPoint(1)
  19.             Case 1
  20.               Pt2 = .StartPoint
  21.               Kk2 = .Delta(1) / .Delta(0)
  22.               .color = 2
  23.           End Select
  24.         Next jj
  25.       End With
  26.       ii = ii + 1
  27.     Next Ent
  28.     Pp = objLine(0).IntersectWith(objLine(1), acExtendBoth)
  29.     Debug.Print Pp(0), Pp(1)
  30.     Pp1 = TowLinesIntersect(Pt1, Kk1, Pt2, Kk2)
  31.     Debug.Print Pp1(0), Pp1(1)
  32.   End With
  33. End Sub
  34. Function TowLinesIntersect(Pt1, Kk1, Pt2, Kk2) As Variant
  35.   Dim Pp(2) As Double
  36.   Pp(0) = (Kk1 * Pt1(0) - Pt1(1) - Kk2 * Pt2(0) + Pt2(1)) / (Kk1 - Kk2)
  37.   Pp(1) = (Pp(0) - Pt1(0)) * Kk1 + Pt1(1)
  38.   TowLinesIntersect = Pp
  39. End Function
发表于 2009-9-17 13:56:00 | 显示全部楼层
支持一下呀,学习了
上海上门按摩  上海上门按摩 上海上门按摩 上海上门按摩 上海按摩
发表于 2010-2-8 19:40:00 | 显示全部楼层
怎么回事啊。不能用啊
发表于 2010-2-23 18:34:00 | 显示全部楼层
不是说了要先画两条直线的嘛
GMT+8, 2025-5-26 07:45 , Processed in 0.152030 second(s), 26 queries , Gzip On.
