查看: 3369|回复: 2
在中点画圆+文字
发表于 2009-9-20 08:40:00 | 显示全部楼层 |阅读模式
  1. 'Creates a single line of text.
  2. Function PipeNoText(cadApp As AcadApplication, pp, Str)
  3.   Dim objText As AcadText, objCircle As AcadCircle
  4.   Dim alignmentPoint(0 To 2) As Double
  5.   For ii = 0 To 2
  6.     alignmentPoint(ii) = pp(ii) '+ 0.001
  7.   Next ii
  8.   With cadApp.ActiveDocument.ModelSpace
  9.     Set objText = .AddText(Str, pp, 4)
  10.     With objText
  11.      ' .Layer = "件号"
  12.       .Alignment = acAlignmentMiddleCenter
  13.       .TextAlignmentPoint = alignmentPoint 'alignmentPoint
  14.     End With
  15.     Set objCircle = .AddCircle(pp, 4)
  16.     With objCircle
  17.       '.Layer = "件号"
  18.     End With
  19.   End With
  20. End Function
  21. Sub ll()
  22.   Dim cadApp As AcadApplication, objLine As AcadLine
  23.   Dim Pt
  24.   With ThisDrawing
  25.     Set cadApp = ThisDrawing.Application
  26.     Set objLine = .HandleToObject("89B")
  27.     Pt = midPtOneLine(cadApp, objLine)
  28.     temp = PipeNoText(cadApp, Pt, "ee")
  29.   End With
  30.
  31. End Sub
  32. Function midPtOneLine(cadApp As AcadApplication, objLine As AcadLine) As Variant
  33.    Dim Pt(2) As Double
  34.    With objLine
  35.      Pt(0) = .StartPoint(0) + (.EndPoint(0) - .StartPoint(0)) / 2
  36.      Pt(1) = .StartPoint(1) + (.EndPoint(1) - .StartPoint(1)) / 2
  37.    End With
  38.    midPtOneLine = Pt
  39.    Exit Function
  40.    For ii = 0 To 2
  41.      'midPtOneLine(ii) = Pt(ii)
  42.    Next ii
  43. End Function
发表于 2020-5-16 19:22:44 | 显示全部楼层
这个函数很好,怎么用这个函数呢?版主写一个调用这个函数的小程序吧 好吗 谢谢
发表于 2022-12-7 10:56:49 | 显示全部楼层
temp问题在这里
GMT+8, 2025-10-18 05:40 , Processed in 0.564145 second(s), 23 queries , Gzip On.
