查看: 1458|回复: 0
三角形方向箭的应用.
发表于 2009-9-22 20:48:00 | 显示全部楼层 |阅读模式
  1. Sub ls1()
  2.   Dim oSolid As AcadSolid
  3.   With ThisDrawing.ModelSpace
  4.     Dim xySolidArr(1)
  5.     Dim Pt1(2) As Double, Pt2(2) As Double, Pt3(2) As Double, Pt4(2) As Double
  6.     xySolidArr(0) = Array(0, 0, 0, 2.5, -0.5, 0, 2.5, 0.5, 0, 2.2, 0, 0)
  7.     xySolidArr(1) = Array(2.2, -0.1, 0, 5, -0.1, 0, 2.2, 0.1, 0, 5, 0.1, 0)
  8.     For ii = 0 To 1
  9.       For jj = 0 To 2
  10.         Pt1(jj) = xySolidArr(ii)(jj)
  11.         Pt2(jj) = xySolidArr(ii)(jj + 3)
  12.         Pt3(jj) = xySolidArr(ii)(jj + 6)
  13.         Pt4(jj) = xySolidArr(ii)(jj + 9)
  14.       Next jj
  15.       Set oSolid = .AddSolid(Pt1, Pt2, Pt3, Pt4)
  16.       With oSolid
  17.         .Layer = 0
  18.       End With
  19.     Next ii
  20.   End With
  21. End Sub
GMT+8, 2025-5-28 01:34 , Processed in 0.177453 second(s), 24 queries , Gzip On.
