查看: 1509|回复: 2
怎么获取dcl-onwx开关的值
发表于 2009-9-23 09:05:00 | 显示全部楼层 |阅读模式
怎么获取dcl-onwx开关的值
 楼主| 发表于 2009-9-23 09:05:00 | 显示全部楼层
;;;______________________分隔线________________________________
(defun c:FZZ ()
  (setvar "cmdecho" 0)
  (dcl_FZZ)
  (prin1)
(defun dcl_FZZ ()
  (setq dcl_id (load_dialog "Q_FZZ"))
  (new_dialog "Q_FZZ" dcl_id)
  (def_FZZ)
  (action_tile "kimage1" "(setq ddtype 1)")
  (action_tile "kimage2" "(setq ddtype 2)")
  (action_tile "kimage3" "(setq ddtype 3)")
  (action_tile "kimage4" "(setq ddtype 4)")
  (action_tile "kimage5" "(setq ddtype 5)")
  (action_tile "kimage6" "(setq ddtype 6)")
  (action_tile "kimage7" "(setq ddtype 7)")
;;;  (action_tile "dcl-onwx" "(ok_FZZ)")
  (action_tile "bb3" "(qdio_zuozhe)")
  (action_tile "accept" "(ok_FZZ)(done_dialog 1)")
  (setq dd (start_dialog))
  (if (= dd 1)
    (draw_FZZ)
  (if (= dd 5)
      (setq dcl_id2 (load_dialog "ty.dcl"))
      (new_dialog "zuozhe_dcl" dcl_id2)
      (action_tile "accept" "(done_dialog 0)")
(defun def_FZZ ()
  (set_tile "kww" "100")
  (set_tile "khh" "60")
  (setq sldkey_list
  '("kimage1" "kimage2" "kimage3" "kimage4" "kimage5" "kimage6"
    "kimage7")
  (setq sld_list '("XG_Z" "CT_P" "CT_FL" "XG_QZ" "CT_X" "CT_L" "XG_Z3"))
  (mapcar 'show_sld sldkey_list sld_list)
(defun show_sld (key sld)
  (setq x (dimx_tile key))
  (setq y (dimy_tile key))
  (start_image key)
  (fill_image 0 0 x y -2)
  (slide_image 0 0 x y sld)
  (end_image)
***************************************此处获取值*****************************************************
(defun ok_FZZ () (setq onwx2 (atoi (get_tile "dcl-onwx"))))
(defun draw_FZZ ()
  (cond
    ((= ddtype 1) (draw_XG_Z))
    ((= ddtype 2) (draw_CT_P))
    ((= ddtype 3) (draw_CT_FL))
    ((= ddtype 4) (draw_XG_QZ))
    ((= ddtype 5) (draw_CT_X))
    ((= ddtype 6) (draw_CT_L))
    ((= ddtype 7) (draw_XG_Z3))
 楼主| 发表于 2009-9-23 09:06:00 | 显示全部楼层
DCL
Q_FZZ:dialog{
 label="图像按钮辅助【入子侧视】";
 :boxed_column{
  label="视图样式";
  :row{:image_button {key = "kimage1";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage2";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage3";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}}
  :row{:image_button {key = "kimage4";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage5";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage6";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}}
  :row{:image_button {key = "kimage7";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage8";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}
       :image_button {key = "kimage9";color = -2;width = 30;aspect_ratio = 0.8;allow_accept = true;}}
          spacer_1;
           :boxed_column{:toggle{label="绘制零件外框";key="dcl-onwx";}fixed_width=true;alignment=centered;}
   spacer_1;
          :row{fixed_width=true;alignment=centered;
        :row{:button{label="确定";key="ok";is_default=true;}
      :button{label="取消";key="Ca";is_cancel=true;}}
               :button{label="关 于";key="bb3";}}
GMT+8, 2025-2-24 02:23 , Processed in 0.158400 second(s), 26 queries , Gzip On.
