我还有个问题请教大家,我在用cad打印功能来获得tiff格式文件的时候,得到的最后tiff文件在打开后总是在图的周围有白色边界,不是我想要的整个地形图布满整张图纸的。因为要把一幅幅的tiff文件用来拼图,所以要得到布满图纸的tiff文件。以下是我的代码,麻烦大侠们帮我看看,本人不甚感激。 ...... (setq ActiveLayout(vla-get-ActiveLayout CadDocument) ) (setq layoutSel(vla-get-Layouts CadDocument)) (setq clayout(vla-item layoutSel "Layout1")) (vla-put-ConfigName clayout "TIFF Version 6 (不压缩).pc3") (vla-put-standardscale ActiveLayout acscaletofit) (vla-put-centerplot ActiveLayout :vlax-true) ....获得图形的最右上角点point1,左下角点point2后 (vla-put-ConfigName clayout "TIFF Version 6 (不压缩).pc3") (vla-put-standardscale ActiveLayout acscaletofit) (vla-put-centerplot ActiveLayout :vlax-true) ....获得图形的最右上角点point1,左下角点point2后 (vla-SetWindowToPlot ActiveLayout point1 point2) (vla-put-plottype ActiveLayout acWindow) (vla-Regen mACadDocument :vlax-true) (vla-put-plotrotation ActiveLayout ac0degrees) (vla-put-StyleSheet ActiveLayout "monochrome.ctb") (setq filename "112") (setq result (vla-PlotToFile (vla-get-Plot CadDocument) filename)) |
