怎么修改实现不用选择而自动吧字体变换 (defun C:ets(/ s1 ename ti% p11 p10 f en p11n p10n fn fn1) (princ "ET-Supper Made by LeaLeung.\n") ;超级ET程式制造者:黎亮! (princ "Select Text to change:\n") (setq s1 (ssget '((0 . "TEXT"))) ;构造针对TEXT的选择集 ) (setq ti% 0) (if (/= s1 nil) (progn (while (<= ti% (- (sslength s1) 1) ) (setq ename(ssname s1 ti%)) (setq p11 nil) ;将p11置空 (setq e (entget ename)) ;取实体表e (setq p11 (assoc 11 e)) ;取对齐点 (setq p10 (assoc 10 e)) ;取其始点表 (setq f (assoc 10 e)) ;如上 (setq en e) (if (= (cdr f) 0) (setq p11n (cons 11 (cdr p10)))) (if (/= (cdr f ) 0) (progn (setq p10n (cons 10 (cdr p11)));将对齐点位构成其始点表赋给p10n (setq en (subst p10n p10 en)) ;用新的其始点位更换旧的其始 点表 ) ) (setq fn 0) (setq fn (cons 72 fn)) ;(72 . 0) 为左齐 (setq fn1 (assoc 72 en)) ;取旧的对齐方式 (setq e (subst fn fn1 e)) ;更换旧的对齐方式为左齐 (entmod e) (setq ti%(+ 1 ti%)) ) ;end while ) ;endprogn s1/=nil ) ;endif s1 /= nil (setq s1 nil) (princ "Made by LeaLeung") ;LeaLeung 就是我 黎亮! ) (defun C:et(/ s1 ename ti% p11 p10 f en p11n p10n fn fn1) (princ "Select Text to change:\n") (setq s1 (ssget '((0 . "TEXT"))) ;构造针对TEXT的选择集 )
(setq ti% 0) (if (/= s1 nil) (progn (while (<= ti% (- (sslength s1) 1) ) (setq ename(ssname s1 ti%)) (setq p11 nil) ;将p11置空 (setq e (entget ename)) ;取实体表e (setq p11 (assoc 11 e)) ;取对齐点 (setq p10 (assoc 10 e)) ;取其始点表 (setq f (assoc 10 e)) ;如上 (setq en e) (if (= (cdr f) 0) (setq p11n (cons 11 (cdr p10)))) (if (/= (cdr f ) 0) (progn (setq p10n (cons 10 (cdr p11)));将对齐点位构成其始点表赋给p10n (setq en (subst p10n p10 en)) ;用新的其始点位更换旧的其始 点表 ) ) (setq fn 0) (setq fn (cons 72 fn)) ;(72 . 0) 为左齐 (setq fn1 (assoc 72 en)) ;取旧的对齐方式 (setq e (subst fn fn1 e)) ;更换旧的对齐方式为左齐 (entmod e) (setq ti%(+ 1 ti%)) ) ;end while ) ;endprogn s1/=nil ) ;endif s1 /= nil (setq s1 nil) ) |
