查看: 2027|回复: 5
[基础] [求助]lisp当中选择一个对象的命令是什么?
发表于 2009-10-7 09:45:00 | 显示全部楼层 |阅读模式
各位大侠:
我找了一个计算相同块数量的程序,但是我想在计算后能够把统计的块同时选择上,请问该加一句什么呢?谢谢各位大侠了。。
程序如下:
(defun c:CalBlk( / ent ents blkname)
  (setq ent (car (entsel)))
  (if ent
      (setq ents (entget ent))
      (if (= (cdr (assoc 0 ents)) "INSERT")
   (setq blkname (cdr (assoc 2 ents)))
   (princ (strcat "\n块名:" blkname "," "数量:"))
   (princ (sslength (ssget "x" (list '(0 . "INSERT") (cons 2 blkname)))))
(prompt "Enter CALBLK to launch the program!")
发表于 2009-10-7 10:28:00 | 显示全部楼层
  1. (defun c:CalBlk( / ent ents blkname)
  2.   (setq ent (car (entsel)))
  3.   (if ent
  4.     (progn
  5.       (setq ents (entget ent))
  6.       (if (= (cdr (assoc 0 ents)) "INSERT")
  7. (progn
  8.    (setq blkname (cdr (assoc 2 ents)))
  9.    (princ (strcat "\n块名:" blkname "," "数量:"))
  10.    (princ (sslength (sssetfirst gripset (ssget "x" (list '(0 . "INSERT") (cons 2 blkname))))))
  11. )
  12.       )
  13.     )
  14.   )
  15.   (princ)
  16. )
  17. (prompt "Enter CALBLK to launch the program!")
 楼主| 发表于 2009-10-7 10:30:00 | 显示全部楼层
呵呵,谢谢了哈。。好同志
 楼主| 发表于 2009-10-7 10:33:00 | 显示全部楼层
选择对象:
块名:p,数量:; 错误: 参数类型错误: lselsetp (nil <Selection set: 32c>)
命令:
提示错误哈,但能选择!!
发表于 2009-10-7 12:26:00 | 显示全部楼层
(princ (strcat "\n塊名:" BLKNAME "," "數量:"))
   (sssetfirst
     GRIPSET
     (setq
       SS (ssget "x" (list '(0 . "INSERT") (cons 2 BLKNAME)))
   (princ (sslength SS))
发表于 2009-10-7 14:21:00 | 显示全部楼层
按版主龙龙仔的改法修改就可以了.以下是我重新改进的代码:
  3.    (if ent
  4.      (progn
  7.   (progn
  10.     (princ (sslength (setq ss (ssget "x" (list '(0 . "INSERT") (cons 2 blkname))))))
  11.   )
  12.        )
  13.     (sssetfirst gripset ss)
  14.      )
  15.    )
  16.    (princ)
  17. )
  18. (prompt "Enter CALBLK to launch the program!")
GMT+8, 2025-2-19 07:08 , Processed in 0.149205 second(s), 25 queries , Gzip On.
