查看: 893|回复: 0
求助DCL控制画圆
明经网友  发表于 2009-10-8 18:21:00 |阅读模式
我弄了个画圆的程序,不知道哪里有问题,无法实现DCL控制画圆,求高手帮忙看看
lsp程序
(defun c:rect()
 (setq dcl_id (load_dialog "circle"))
 (new_dialog "rect" dcl_id)
 (action_tile "accept" "(sae_alue)")
 (start_dialog) (unload_dialog dcl_id)
(defun c:yuan()
 (setq pt (getpoint "输入圆心坐标:"))
 (setq r (getreal "输入半径"))
 (command "circle" pt r )
(defun sae_alue ()
 (setq r (atof (get_tile "react_h"))
 (setq pt (atof (get_tile "react_w"))
 (done_dialog)
DCL程序
rect:dialog
{ label="画圆程序" ;
:edit_box //编辑框元件
{ label="输入圆心 : " ;
key="rect_w" ;
edit_limit=16;
edit_width=20;
fixed_width=true;
:edit_box //编辑框元件
{ label="输入半径 :" ;
key="rect_h" ;
edit_limit=16;
edit_width=20;
fixed_width=true;
ok_cancel;
使用道具
GMT+8, 2025-2-24 02:54 , Processed in 0.153561 second(s), 23 queries , Gzip On.
