查看: 1017|回复: 1
{求助}大侠帮帮忙
发表于 2009-10-12 16:59:00 | 显示全部楼层 |阅读模式
;;;首曲线
(command "layer" "s" "0" "")
(setq a (ssget "x" (setq exdata'((-3("south"(1000 . "201101")))))))
(if a
(setq i 0)
(setq len (sslength a))
(repeat len
(setq b (ssname a i))
(command "pedit" b "w" "0.1" "" )
(setq i(+ i 1))
);end repeat
(if a
(setq i 0)
(repeat len
(setq i(+ i 1))
);end repeat
看看那个大侠能帮我改一下,我想处理二维多段线
这个只能处理多段线
发表于 2009-10-12 17:09:00 | 显示全部楼层
(setq a (ssget "x" (setq exdata'((0 . "polyline")))))))
GMT+8, 2025-2-23 22:51 , Processed in 0.186810 second(s), 25 queries , Gzip On.
