查看: 14324|回复: 21
[函数] 最佳的DCL代替方案,轻松实现VBA移植至Vlisp,动态创建、调用VBA窗体通用函数
发表于 2009-10-16 12:46:00 | 显示全部楼层 |阅读模式
Vlisp动态创建、调用VBA窗体通用函数:c:ysx-make-vbaform ,轻松实现VBA移植至Vlisp
发表于 2018-6-2 10:19:02 | 显示全部楼层
B
由于CAD的版本更新太夸张。ARX的编译版本太多,所以我一直用VB的DLL来实现。效果很好。不用频繁的更新软件了。
发表于 2018-6-2 17:14:22 来自手机 | 显示全部楼层
NetBee 发表于 2018-6-2 10:19
由于CAD的版本更新太夸张。ARX的编译版本太多,所以我一直用VB的DLL来实现。效果很好。不用频繁的更新软件 ...
前辈,vb是指vb.net还是指vb6调用DLL用于64位CAD?如果vb6可实现,老师能否给个链接学习学习下,谢谢!
 楼主| 发表于 2022-7-11 12:02:58 | 显示全部楼层
这是个好办法,但对于64位,好像要用到exe,不能用dll
 楼主| 发表于 2009-10-16 12:46:00 | 显示全部楼层
格式:(c:ysx-make-vbaform  VbaList)
VbaList--1(list {窗体(组件)列表} 2{窗体和组件属性列表} 3{预留} 4{自定义函数/事件代码列表} 5{API声明列表+Const常数列表+DIM/Private声明列表}
例子:
(defun c:yf()
  (c:ysx-make-vbaform
    (list (list "Form" "ChinaForm"
                (list "Image" "Image1")
                (list "CommandButton" "CommandButton1")
          );窗体组件列表
          (list (list "ChinaForm" "caption" "悬浮窗体" "width" 510 "height" 409)
                (list "Image1" "left" 0 "top" 0 "width" 506 "height" 383 "AutoSize" 1)
                (list "CommandButton1" "left" 260 "top" 250 "width" 75 "height" 20 "caption" "绘制直线")
          ) ;窗体和组件属性列表
          nil
          (list
                (list "Private Sub CommandButton1_Click()" "ThisDrawing.SendCommand \"line \"" "End Sub")
                (list "Private Sub UserForm_Activate()" "ChinaForm.Left = 0" "ChinaForm.top = 80" "End Sub")
                (list "Private Sub Image1_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)"
                      "If ChinaForm.Left <> 0 Then" "ChinaForm.Left = 0" "ChinaForm.Top = 80" "End If" "End Sub"
                (list "Private Sub Image1_Click()" "If ChinaForm.Left =0 Then" "ChinaForm.Left = -507" "ChinaForm.top = 80" "End If" "End Sub")
baitang36 + 1 很给力!
 楼主| 发表于 2009-10-16 12:58:00 | 显示全部楼层
 楼主| 发表于 2009-10-16 13:05:00 | 显示全部楼层
(defun c:yf()
  (c:ysx-make-vbaform
                (list "Frame" "Frame1"
                      (list "TextBox" "text1")
                      (list "Frame" "Frame2"
                            (list "TextBox" "text3")
                (list "TextBox" "text2")
          );窗体组件列表
          (list (list "ChinaForm" "caption" "悬浮窗体" "width" 110 "height" 200 "top" 110 "left" 1300)
                (list "Frame1" "left" 4 "top" 4 "width" 98 "caption" "选项")
                (list "text1" "width" 85 "left" 4 "top" 4 "text" "输入内容")
                (list "Frame2" "width" 88 "height" 100 "left" 4 "top" 30 "caption" "中了")
                (list "text3" "left" 4 "top" 5)
                (list "text2" "left" 4 "top" 220)
          ) ;窗体和组件属性列表
          nil
          (list
                (list "Private Sub text3_Change()" "text3.Text = Time$" "End Sub")
                (list "Private Sub UserForm_Activate()" "ChinaForm.Left = 0" "ChinaForm.top = 60" "End Sub")
                (list "Private Sub UserForm_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)"
                      "If ChinaForm.Left <> 0 Then" "ChinaForm.Left = 0" "ChinaForm.Top = 60" "End If" "End Sub"
                (list "Private Sub UserForm_Click()" "If ChinaForm.Left =0 Then" "ChinaForm.Left = -106" "ChinaForm.top = 60" "End If" "End Sub")
发表于 2009-10-16 16:03:00 | 显示全部楼层
把dvb文件用Lisp以二进制文本方式储存
临时写出去转为dvb格式再倒入CAD
就可以实现把图片等信息都弄进Lisp里面!
 楼主| 发表于 2009-10-16 16:32:00 | 显示全部楼层
nonsmall发表于2009-10-16 16:03:00把dvb文件用Lisp以二进制文本方式储存临时写出去转为dvb格式再倒入CAD就可以实现把图片等信息都弄进Lisp里面!
这样复杂化了,把图片保存在文件夹中,需要时才加载,动态化
 楼主| 发表于 2009-10-19 10:00:00 | 显示全部楼层
即时动态获取输入数据
明经网友  发表于 2009-10-19 11:54:00
如何不会vba的,也不调用这个函数。
如果会vba的搞这么复杂还不如直接做个dvb文件得了(可视化)
总结,想法是非常不错的,实用性没有!
使用道具
发表于 2009-10-19 12:06:00 | 显示全部楼层
如果不会vba也不会调用这个函数。
如何会vba也不会这么复杂的去这么做,还不如直接做个dvb文件得了(可视化)
总结:思路还不错,实用性不强。
 楼主| 发表于 2009-10-19 15:58:00 | 显示全部楼层
如果不会VBA,那就谈不上VBA移植的问题,讨论这个问题就是以有一定VBA的基础知识为前提的
做个dvb文件(可视化),就我认为,实在也不是那么简单,做好工程后保存,手动或编个VLisp程序调用,也不怎么方便。
Vlisp的优缺点是什么呢?优点:表处理,开发资源和源码,网上多的是,使用方便;缺点:DCL的方便性实在不怎么样;
VBA的特点呢?优点:界面处理绝对是它的一大特色;缺点:相对于Vlisp,VBA方便性要差一些;
如果将两者结合一起,取长补短,于是有了这个函数的产生。
在使用方面,我认为可以这样:
1、Vlisp水平要好一点,VBA水平一般的,不妨着重使用它调用窗体功能,相对于DCL,VBA窗体处理要方便,配合VBA的触发事件,结合使用;
一般来说,掌握好控件的left、top、width、height四个属性就基本OK了
3、Vlisp和VBA水平相对平衡的,最好结合使用,取长补短;
3、VBA高手的,Vlisp不咋的,建议你还是用回VBA吧
每个人的情况不同,对事情的看法也不同,所以只能是见仁见智了
GMT+8, 2025-5-23 15:19 , Processed in 0.186514 second(s), 28 queries , Gzip On.
