查看: 1950|回复: 0
请高手完善程序,标注出不同全局比例的尺寸标注
发表于 2009-10-22 09:56:00 | 显示全部楼层 |阅读模式
欲达目的:能标注出不同全局比例的尺寸标注
;;;线性标注
(defun c:DSS (/ scal oldfac al a2 sa b1 i BL )
(setvar "cmdecho" 0)
(setvar "pickbox" 23)
(setq scal   (getvar "dimscale"))
(command "-DIMSTYLE" "R" "TH_GBDIM")
(IF (SETQ A (entlast))
(PROGN (SETQ BL (GETDIST
(strcat "\n 请输入新标注全局比例(全局标注比例默认值<" (rtos scal 2) ">):" )
(if (/= BL Nil)(setq scal BL)))
(princ "\n 选择线性标注点:")
(command "DIMLINEAR" )
;(command "dim1" "new" "<>" PAUSE "")
;(command "dim1" "new" (strcat "<>")
;(command "dim1" "dimscale" BL "" "Updat" A "" "EXIT" )
(SETVAR "dimscale" scal)
GMT+8, 2025-5-25 11:44 , Processed in 0.153714 second(s), 24 queries , Gzip On.
