查看: 1936|回复: 0
请高手更改程序,编辑填充角度
发表于 2009-10-23 10:37:00 | 显示全部楼层 |阅读模式
目的:如果角度为0度,那么编辑填充角度为90度
           如果角度为90度,那么编辑填充角度为0度
;;;编辑填充角度
(defun c:EH (/ SS SS1)(STRCAT "请拾取填充区域进行编辑角度为90°")(setvar "pickbox" 23)
(setq SS (ssget))(setq SS1 (ssadd))(ssadd (entlast) SS1)(repeat (sslength SS1))
(command "change" SS "" "p" "c" "BYLAYER" "la" "剖面线层" "" "_.hatchedit" SS "" "" "" "90" ))
GMT+8, 2025-5-25 12:24 , Processed in 0.171658 second(s), 24 queries , Gzip On.
