查看: 1573|回复: 4
[求助]cad有多个layout时,如何指定每个layout?
发表于 2009-10-23 21:35:00 | 显示全部楼层 |阅读模式
thisdrawing.paperspace.add....
如果我有layout1,layout2等,paperspace只默认指定一个.
 楼主| 发表于 2009-10-23 21:45:00 | 显示全部楼层
Option Explicit
Public Sub Add_Order_Number()
Dim dblStart(0 To 2) As Double  '插入点
Dim dblHeight As Double
Dim strText As String
Dim objOrderText As AcadText
Dim PP As Object
dblStart(0) = 338.5473
dblStart(1) = 27.3814
dblStart(2) = 0
dblHeight = 4.8
strText = "订单:72E172A,B,C"         '测试用,最终会改为变量
Set objOrderText = ThisDrawing.PaperSpace.AddText(strText, dblStart, dblHeight)         '在paperspace写字,但有2个以上的layout时,如何每个都写入?
With objOrderText
    .Alignment = acAlignmentMiddleCenter
    .TextAlignmentPoint = dblStart  '调整该对齐属性的文字插入点(必须)
End With
objOrderText.Update
End Sub
 楼主| 发表于 2009-10-24 19:07:00 | 显示全部楼层
  继续等待大侠帮忙.
发表于 2009-10-24 19:33:00 | 显示全部楼层
Public Sub mtest() '循环每个空间
    Dim mLayout As AcadLayout
    For Each mLayout In ThisDrawing.Layouts
        ThisDrawing.ActiveLayout = mLayout
        MsgBox ("当前空间为" & mLayout.Name)
    Next
End Sub
 楼主| 发表于 2009-10-25 09:20:00 | 显示全部楼层
ok,测试成功,就是把modelspace也算进去了
那么,直接用ThisDrawing.PaperSpace 指定不行么,好像
GMT+8, 2025-5-26 09:05 , Processed in 0.166230 second(s), 24 queries , Gzip On.
