最近在学习LISP,看别人写的一个文字合并的程序. 我在CAD上试运行了一下,结果居然是:0.000000不是合并后的文字. 我看了半天,不知道哪错了,有高手能指点指点吗? ;文字合并程序 ; this program is make letter together (defun c:wzhb() (command "osnap" "off") (setq kg1 (getint"\n合并字符间空格数0~10<0>:")) (if (= kg1 nil)(setq kg11 "")) (if (= kg1 0)(setq kg11 "")) (if (= kg1 1)(setq kg11 " ")) (if (= kg1 2)(setq kg11 " ")) (if (= kg1 3)(setq kg11 " ")) (if (= kg1 4)(setq kg11 " ")) (if (= kg1 5)(setq kg11 " ")) (if (= kg1 6)(setq kg11 " ")) (if (= kg1 7)(setq kg11 " ")) (if (= kg1 8)(setq kg11 " ")) (if (= kg1 9)(setq kg11 " ")) (if (= kg1 10)(setq kg11 " ")) (setq zzz "") (princ "\n选择字符串:") (setq s (ssget)) (setq n (sslength s)) (setq k 0 )(setq cgm 0) (setq fxx nil) (setq fyy nil) (setq fzz nil) (setq pxx1 nil) (setq pyy1 nil) (while (< k n) (setq name (ssname s k)) (setq a (entget name)) (setq bhz (assoc '0 a)) (setq bhz (cdr bhz)) (if (= bhz "TEXT") (progn (if (= k 0) (progn (setq b (assoc '0 a)) (setq b (cdr b)) (setq h0 (assoc '40 a)) (setq h0 (cdr h0)) (setq ag1 (assoc '50 a)) (setq ag1 (cdr ag1)) (setq ag1 (* ag1 180) ag1 (/ ag1 pi)) )) (setq nam1 (assoc '-1 a)) (setq nam1 (cdr nam1)) (setq xxx (assoc '10 a)) (setq xy (cdr xxx)) (setq xx (car xy) yy (cdr xy) yy (car yy)) (setq tx1 (assoc '1 a)) (setq tx1 (cdr tx1)) (setq lxx (list xx tx1)) (setq lyy (list yy tx1)) (setq lxx (list lxx)) (setq lyy (list lyy)) (setq fxx (append fxx lxx)) (setq fyy (append fyy lyy)) (setq pxx (list xx) pyy (list yy)) (setq pxx1 (append pxx1 pxx) pyy1 (append pyy1 pyy)) (entdel nam1) (setq cgm (+ cgm 1)) )) (setq k (+ k 1)) ) (setq pxx1 (vl-sort pxx1 '<)) (setq pyy1 (vl-sort pyy1 '<)) (setq px (car pxx1) py (car pyy1)) (setq p1 (list px py)) (if (= ag1 0.0)(progn (setq fzz (vl-sort fxx (function (lambda (e1 e2) (< (car e1) (car e2)))))) )) (if (> ag1 0)(progn (setq fzz (vl-sort fyy (function (lambda (e1 e2) (< (car e1) (car e2)))))) )) (setq nn 0) (while (< nn cgm) (setq zz1 (car fzz)) (setq zz1 (cdr zz1) zz1 (car zz1)) (setq zzz (strcat zzz kg11 zz1)) (setq fzz (cdr fzz)) (setq nn (+ nn 1)) ) (command "text" p1 h0 ag1 zzz) (command "osnap" "int,mid,nea,cen,per,tan") ) |
