查看: 1990|回复: 4
[基础] 为什么参数太少???
发表于 2009-11-12 13:29:00 | 显示全部楼层 |阅读模式
(DEFUN C:pma()  (SETQ DCL_ID (LOAD_DIALOG "aaa"))
 (NEW_DIALOG "aaa" DCL_ID)
 (ACTION_TILE "accept" "(S_RECT)(DONE_DIALOG)")
 (START_DIALOG)(UNLOAD_DIALOG)
 (PRINC))
(DEFUN S_RECT()
(setq fff (atoi (get_tile "pma_type")))
(if (>= fff 0)
(cond ((= 0 fff)
           (setq kkk (get_tile "pma_pn"))
           (ALERT (STRCAT KKK "YES"))
            ((= 1 fff)
         (ALERT (STRCAT KKK "NO"))
(c:pma)
 楼主| 发表于 2009-11-12 13:31:00 | 显示全部楼层
DCL如下
dcl_settings : default_dcl_settings { audit_level = 3; }
aaa : dialog {
    label = "PMA系统";
    : boxed_row {
        label = "打印信息";
        mnemonic = "???";
        : edit_box {
            label = "打印张数";
            key = "pma_pn";
        : popup_list {
            label = "纸张类型";
            key = "pma_type";
            list = "白图\n硫酸纸";
    ok_only;
发表于 2009-11-12 17:18:00 | 显示全部楼层
参数传递的问题?
发表于 2009-11-13 19:56:00 | 显示全部楼层
问题解决,修改后代码如下:
(DEFUN C:pma ()
  (START_DIALOG)
  (UNLOAD_DIALOG DCL_ID)
  (PRINC)
(DEFUN S_RECT ()
  (if (>= fff 0)
      (cond ((= 0 fff)
     ((= 1 fff)
发表于 2010-9-28 10:46:00 | 显示全部楼层
我也遇到这个问题,学习了!
GMT+8, 2024-10-2 12:26 , Processed in 0.149809 second(s), 25 queries , Gzip On.
