查看: 1563|回复: 1
如何用ActiveX创建一个图层?
发表于 2003-6-27 11:07:00 | 显示全部楼层 |阅读模式
我想用ActiveX方法创建一个图层,却发现并没有vla-addlayer函数?是真的吗?怎么办?
发表于 2003-6-27 11:19:00 | 显示全部楼层
;以下是加载删除线型,添加删除图层,并设定其颜色,
(vl-load-com)
(defun listline(/ adoc ltps n i ltp1)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq ltps (vla-get-linetypes adoc))
  (setq n (vla-get-count ltps))
  (setq i 3)
  (repeat (- n 3)
    (setq ltp1 (vla-item ltps i))
    (princ "\n")
    (print (vla-get-name ltp1))
    (princ "\n")
    (setq i (1+ i))
(defun c:loadline(/ adoc msp ltps lname)
  (setq lname (getstring "输入需要添加的线型:"))
  (setq ltp (vl-catch-all-apply 'vla-load (list ltps lname "acadiso.lin")))
  (if (vl-catch-all-error-p ltp)
    (princ "此线型已存在!")
(defun c:delline(/ adoc msp ltps ltp lname)
  (setq lname (getstring "输入需要删除的线型<*>:"))
  (if (= lname "") (listline))
  (while (= lname "")
    (setq lname (getstring "输入需要删除的线型[List]:"))
    (if (= (strcase lname 0) "l") (progn (listline) (setq lname "")))
  (setq ltp (vl-catch-all-apply 'vla-item (list ltps lname)))
    (princ "没有此线型!")
    (vla-delete ltp)
(defun c:dellayer(/ adoc msp ltps ltp lname)
  (setq ltps (vla-get-layers adoc))
  (setq lname (getstring "输入需要删除的图层<*>:"))
  (if (= lname "") (listlayer))
  (while (= lname "")
    (setq lname (getstring "输入需要删除的图层[List]:"))
    (if (= (strcase lname 0) "l") (progn (listlayer) (setq lname "")))
    (princ "没有此图层!")
    (vla-delete ltp)
(defun listlayer(/ adoc ltps n i ltp1)
  (setq i 0)
  (repeat (- n 0)
    (princ "\n")
    (princ "\n")
    (setq i (1+ i))
(defun Newlayer(lname lcolor / layer layers adoc)
  (setq layers (vla-get-layers adoc))
  (setq layer (vl-catch-all-apply 'vla-item (list layers lname)))
  (if (vl-catch-all-error-p layer)
      (setq layer (vla-add layers lname))
      (vla-put-color layer lcolor)
  (vla-put-ActiveLayer adoc layer)
GMT+8, 2025-4-4 12:32 , Processed in 0.149456 second(s), 26 queries , Gzip On.
