查看: 1268|回复: 3
caoyin 版主进来帮忙
发表于 2009-11-23 00:22:00 | 显示全部楼层 |阅读模式
caoyin版主你上次帮我写了个遍历层图层表得到的EC+日期挺好用,可惜我只懂得一点lisp,vlisp不懂语法,现在工作改变图层改成了change+数字了
现图层里有change1,change2,change11,怎样让程序自动分辨最大的数字,然后就自动生成最大的图层+1生成一个新层
也就是上面的3个图层change11是最大,运行程序后自动生成change12
上次你帮我写的遍历层图层表地址:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=78558&replyID=&skin=1
发表于 2009-11-23 02:33:00 | 显示全部楼层
(defun c:TT1(/ LAYS I)
  (setq LAYS (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))))
  (vlax-for N LAYS
    (if (and (wcmatch (setq N (vla-get-name N)) "change*")
             (setq N (atoi (substr N 7)))
             (or I (setq N I))
             (> N I))
      (setq I N)
  (vl-catch-all-apply 'vla-add (list LAYS (strcat "change" (itoa (1+ I)))))
 楼主| 发表于 2009-11-23 22:01:00 | 显示全部楼层
Command: (setq LAYS (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))))
#<VLA-OBJECT IAcadLayers2 1b9bbe74>
Command: (vlax-for N LAYS
(_>     (if (and (wcmatch (setq N (vla-get-name N)) "change*")
(((_>              (setq N (atoi (substr N 7)))
(((_>              (or I (setq N I))
(((_>              (> N I))
((_>       (setq I N)
((_>     )
(_>   )
nil
Command: (vl-catch-all-apply 'vla-add (list LAYS (strcat "change" (itoa (1+ I)))))
; error: bad argument type: numberp: nil
最後一句調入cad後提示錯誤了!
发表于 2009-11-24 08:10:00 | 显示全部楼层
        (vla-get-activedocument (vlax-get-acad-object))
 I    0
GMT+8, 2025-2-23 11:08 , Processed in 0.194470 second(s), 26 queries , Gzip On.
