查看: 5925|回复: 11
[函数] [原创]发一个通用的含数字的字符串排序的函数(类似资源管理器对文件名的排序方式)
发表于 2009-11-23 01:49:00 | 显示全部楼层 |阅读模式
  XP的资源管理器对文件名进行排序时,对于含数字的文件名(字符串),会按数值的大小进行排序。如:升序时,“文件2”会排在“文件12”的前面。我也编写了一个功能类似的函数,与大家共享。
例:
_$ (setq sl1 '("4" "5" "6" "1" "2" "3" "10" "11" "12" "7" "8" "9" "13" "14" "15")
      sl2 '("4a" "5a" "6a" "1a" "2a" "3a" "10a" "11a" "12a" "7a" "8a" "9a" "13a" "14a" "15a")
      sl3 '("A4" "A5" "A6" "A1" "A2" "A3" "A10" "A11" "A12" "A7" "A8" "A9" "A13" "A14" "A15")
      sl4 '("B4c" "B5c" "B6c" "B1c" "B2c" "B3c" "B10c" "B11c" "B12c" "B7c" "B8c" "B9c" "B13c" "B14c" "B15c")
_$ (TBC:Sort sl1 '<)
("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15")
_$ (TBC:Sort sl2 '<)
("1a" "2a" "3a" "4a" "5a" "6a" "7a" "8a" "9a" "10a" "11a" "12a" "13a" "14a" "15a")
_$ (TBC:Sort sl3 '<)
("A1" "A2" "A3" "A4" "A5" "A6" "A7" "A8" "A9" "A10" "A11" "A12" "A13" "A14" "A15")
_$ (TBC:Sort sl4 '<)
("B1c" "B2c" "B3c" "B4c" "B5c" "B6c" "B7c" "B8c" "B9c" "B10c" "B11c" "B12c" "B13c" "B14c" "B15c")
_$ (TBC:Sort (append sl4 sl3 sl2 sl1) '<)
("1" "1a" "2" "2a" "3" "3a" "4" "4a" "5" "5a" "6" "6a" "7" "7a" "8" "8a" "9" "9a" "10" "10a" "11" "11a" "12" "12a" "13" "13a" "14" "14a" "15" "15a" "A1" "A2" "A3" "A4" "A5" "A6" "A7" "A8" "A9" "A10" "A11" "A12" "A13" "A14" "A15" "B1c" "B2c" "B3c" "B4c" "B5c" "B6c" "B7c" "B8c" "B9c" "B10c" "B11c" "B12c" "B13c" "B14c" "B15c")
函数如下:
;调用说明:lst-字符串列表;func-排序方式。“'<”为升序,“'>”为降序。
(defun TBC:Sort (lst func / Split CompFunc tmp)
  (defun Split (str / tmp i n p x len lst1 lst)
    (setq tmp  (vl-string->list str)
   lst1 (mapcar '(lambda (x) (and (<= 48 x) (<= x 57))) tmp)
   n    (length lst1)
   i    0
    (while (< i n)
      (setq x (nth i lst1)
     i (1+ i)
      (if (= i 1)
 (setq p 1
       len 1
 ) ;else
 (if (= x (nth (- i 2) lst1))
   (setq len (1+ len)) ;else
   (setq tmp (substr str p len)
  tmp (if x
        tmp
        (atoi tmp)
  lst (append lst (list tmp))
  p   i
  len 1
 ) ;if
      ) ;if
    ) ;while
    (if (> n 0)
     tmp (if x
    (atoi tmp)
    tmp
    lst
  (defun CompFunc (lst1 lst2 / tmp do flag i n el1 el2 typ1 typ2)
    (setq i  0
   n  (min (length lst1) (length lst2))
   do T
    (while (and do (<= i n))
      (setq el1  (nth i lst1)
     typ1 (type el1)
     el2  (nth i lst2)
     typ2 (type el2)
     i  (1+ i)
      (if (= typ1 typ2)
 (setq do   (= el1 el2)
       flag (eval (list func el1 el2))
 ) ;else
 (setq do   nil
       flag (or (= typ1 'nil) (= typ2 'STR))
      ) ;if
    ) ;while
    flag
  (setq tmp (mapcar 'Split lst)
 tmp (vl-sort-i tmp 'CompFunc)
 tmp (mapcar '(lambda (x) (nth x lst)) tmp)
  tmp
本帖被以下淘专辑推荐:
发表于 2023-12-16 16:50:49 | 显示全部楼层
redcat 发表于 2010-6-27 09:51
兄弟,其实不用那么复杂,CAD有个函数可以达到你的目的(acad_strlsort list)
再改写一下
(defun sort (ls ...
(SETQ LST (LIST        "2LB14-2-2"  "2LB24-2-1"     "2LB2-2-1"  "2LB2-1" "2LB1-2"
                "2LB1-2"       "2LB2-2"              "2LB2-2-1"
                "2LB2-2-3"     "2LB22-2-2"
(acad_strlsort LST)
("2LB1-2" "2LB1-2" "2LB14-2-2" "2LB2-1" "2LB2-2" "2LB2-2-1" "2LB2-2-1" "2LB2-2-3" "2LB22-2-2" "2LB24-2-1")
发表于 2024-8-30 22:29:43 | 显示全部楼层
收藏了,谢谢分享学习
发表于 2009-11-23 04:12:00 | 显示全部楼层
谢谢分享!下来收藏。
发表于 2009-12-13 14:48:00 | 显示全部楼层
感谢楼主分享
学习了!
发表于 2010-5-28 23:41:00 | 显示全部楼层
好久不来论坛了。发现这种树形列表看帖子很不方便,咋设置下,恢复到以前的那种状态?
程序很好,谢谢啦!
发表于 2010-6-27 09:51:00 | 显示全部楼层
再改写一下
(defun sort (lst mode) ;lst为表,mode为排序模式
  (if mode
    (acad_strlsort lst) ;mode为非nil是升序排列
    (reverse (acad_strlsort lst)) ;mode为nil是降序排列
  ) ;_ 结束if
) ;_ 结束defun
发表于 2010-6-27 11:03:00 | 显示全部楼层
redcat
简单才是最好
发表于 2010-6-27 11:21:00 | 显示全部楼层
redcat发表于2010-6-27 9:51:00兄弟,其实不用那么复杂,CAD有个函数可以达到你的目的(acad_strlsort list) 再改写一下 (defun sort (lst mode) ;lst为表,mode为排序模式  (if mode    (acad_strlsort
您確定有達到樓主的目的?
发表于 2011-1-3 18:15:11 | 显示全部楼层
谢谢分享!下来收藏學習。
发表于 2012-11-28 19:23:34 | 显示全部楼层
楼主辛苦了!!
发表于 2012-12-8 20:03:25 | 显示全部楼层
收藏喽 好用啊 谢谢楼主 学习中
GMT+8, 2025-4-23 01:15 , Processed in 0.173720 second(s), 31 queries , Gzip On.
