查看: 1418|回复: 3
如何正常退出对话框
发表于 2009-11-25 20:37:00 | 显示全部楼层 |阅读模式
(action_tile "cancel" "(done_dialog)(exit)")
按“取消”时,提示出错:错误: quit / exit abort,如何能正常退出对话框呢?
发表于 2009-11-26 15:14:00 | 显示全部楼层
Managing Dialog Boxes
Hiding Dialog Boxes
(defun c:hidedcl (/ dcl_id what_next cnt)
  (setq dcl_id (load_dialog "hidedcl.dcl"))  ;Load the dialog box.
  (setq what_next 2)
  (setq cnt 1)
  (while (>= what_next 2)                    ;Begin display loop.
    (if (null (new_dialog "hidedcl" dcl_id)) ;Initialize dialog
      (exit)                                 ;box, exit if nil
    ); endif                                 ;returned.
    ; Set action to take if a button is pressed. Either button
    ; results in a done_dialog call to close the dialog box.
    ; Each button associates a specific status code with
    ; done_dialog, and this status code is returned by
    ; start_dialog.
    (action_tile "accept" "(done_dialog 1)") ;Set action for OK.
    (action_tile "hide" "(done_dialog 4)")   ;Set action for
                                             ickMe.
    (setq what_next (start_dialog))          ;Display dialog box.
    (cond
      ((= what_next 4)                       rompt user to
        (getpoint "\npick a point")          ;pick pt.
      ((= what_next 0)
        (prompt "\nuser cancelled dialog")
  (unload_dialog dcl_id)
发表于 2009-11-26 17:51:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2009-11-26 21:36:00 | 显示全部楼层
谢谢你们的帮助。
GMT+8, 2025-2-23 11:15 , Processed in 0.166660 second(s), 25 queries , Gzip On.
