查看: 1687|回复: 3
[求助]princ KEY_LST file 函数使用
发表于 2009-11-30 21:04:00 | 显示全部楼层 |阅读模式
(defun dat_gx(/ file)
  (vl-load-com)
  (setq file (strcat (vla-get-path (vlax-get-acad-object)) "\\JWWHZ.DAT")
 file (open file "w"))
  (setq KEY_LST '("changdu" "kuandu" "X_val" "Y_val" "jiaodu" "bili")
  (princ KEY_LST file)
  (close file)))
;;;打开“JWWHZ.DAT”文件写入的是"(changdu kuandu X_val Y_val jiaodu bili)"而不是
;;;   "("2200" "810" "94680" "85180" "110" "6")"文本
;;;是什么原因造成的,要将("2200" "810" "94680" "85180" "110" "6")写入文件如何实现??
;;;以上输入出现错误,原意是写入JWWHZ.DAT”文件的是"(changdu kuandu X_val Y_val jiaodu bili)"而不是
;;;   ("changdu" "kuandu" "X_val" "Y_val" "jiaodu" "bili")
;;;是什么原因造成的,要将("changdu" "kuandu" "X_val" "Y_val" "jiaodu" "bili")写入文件如何实现??
发表于 2009-11-30 22:43:00 | 显示全部楼层
  1. (defun dat_gx (/ file)
  2.   (vl-load-com)
  3.   (setq KEY_LST  '(changdu kuandu X_val Y_val jiaodu bili)
  4. data_LST (list "2200" "810" "94680" "85180" "110" "6")
  5. val_lst  (list changdu kuandu X_val Y_val jiaodu bili)
  6.   )
  7.   (mapcar 'set KEY_LST data_LST)
  8.   (setq filename (strcat (vla-get-path (vlax-get-acad-object)) "\\JWWHZ.DAT")
  9. file (open filename "w")
  10.   )
  11.   (princ val_lst file)
  12.   (close file)
  13. )
 楼主| 发表于 2009-12-1 20:13:00 | 显示全部楼层
谢谢你的回复,但写入到"JWWHZ.DAT中的仍然是(2200 810 94680 85180 110 6)而不是("2200" "810" "94680" "85180" "110" "6")
也就是说(setq val_lst  '("2200" "810" "94680" "85180" "110" "6"))
(setq  file  (open (strcat (vla-get-path (vlax-get-acad-object))    "\\JWWHZ.DAT"   ) "w"))
  (close file)
写入的是(2200 810 94680 85180 110 6)
发表于 2009-12-1 20:53:00 | 显示全部楼层
  (setq data_LST (list "\"2200\"" "\"810\"" "\"94680\"" "\"85180\"" "\"110\"" "\"6\""))
  (princ data_LST file)
GMT+8, 2025-2-23 11:20 , Processed in 0.166413 second(s), 25 queries , Gzip On.
