查看: 3250|回复: 6
cad 批量打印
发表于 2003-6-27 16:05:00 | 显示全部楼层 |阅读模式
有谁用过本站中cad下载中的姚坤批量打印 我怎么用的不好使 只能打最后一张 请赐教
 楼主| 发表于 2003-6-27 16:13:00 | 显示全部楼层
Command:
Command: (load "mplot2plt.lsp")
       c:mplot2plt 已加载; 以mplt启动命令.
Command: mplt 0. No changes, proceed to Plot
1. Merge partial configuration from .pcp file
2. Replace configuration from .pc2 file
3. Save partial configuration as .pcp file
4. Save configuration as .pc2 file
5. Detailed plot configuration
Invalid option keyword.
错误: Function cancelled
Size units (Inches or Millimeters) <M>:
Plot origin in Millimeters <0.00,0.00>:
Rotate plot clockwise 0/90/180/270 degrees <90>:
Adjust area fill boundaries for pen width? <N>
Remove hidden lines? <N>
Specify scale by entering:
Plotted Millimeters=Drawing Units or Fit or ? <F>:
Device Name:  HP LaserJet 5100 Series
Output Port:  HPLaserJet5100Series_copy_9
Driver Version:      5.0
Use the Control Panel to make permanent changes to
a printer's configuration.
Plot device is System Printer ADI 4.3 - by Autodesk, Inc
Description: Default System Printer
Plot optimization level = 0
Plot will NOT be written to a selected file
Sizes are in Millimeters and the style is landscape
Plot origin is at (0.00,0.00)
Plotting area is 195.33 wide by 286.00 high (MAX size)
Plot is rotated 90 degrees
Area fill will NOT be adjusted for pen width
Hidden lines will NOT be removed
Plot will be scaled to fit available area
Enter choice, 0-5 <0>:
Effective plotting area:  195.33 wide by 276.25 high
Plot complete.
发表于 2003-7-16 09:39:00 | 显示全部楼层
CAD自带批打印程序.
发表于 2003-7-16 17:12:00 | 显示全部楼层
批量打印是不是将一张图连续打印N张?要是那样的话,不如在打印机里设置一下就行了.
发表于 2003-7-27 15:31:00 | 显示全部楼层
我的批量打印软件和cad自带的不一样,也不是将一张图打N张,而是将一个dwg中您所画的所有图一次作成plt文件,是为了减少您作完工程后出图的劳动强度,软件通过在图上设置打印标记的办法记录下每张图的打印范围,出图角度和出图比例等信息,然后软件自动读取这些信息进行作plt文件的工作。您可以一试。现在是V2.2版本了。
发表于 2003-8-6 14:30:00 | 显示全部楼层
姚坤批量打印v2.2在R14以上版本可能不能用
发表于 2003-8-6 17:41:00 | 显示全部楼层
针对你想要的功能,我已在本论坛上传过PLOT批处理工具
欢迎使用
有什么问题写信给我,
GMT+8, 2025-11-26 23:14 , Processed in 0.265244 second(s), 23 queries , Gzip On.
