查看: 1710|回复: 0
[函数] 高手来看下,变动变量的局部变量设置问题
发表于 2009-12-14 16:58:00 | 显示全部楼层 |阅读模式
(defun Split (str bi-i)
 (setq j (vl-string-position (ascii "值") str)
       k (vl-string-position (ascii " ") str)
       sz (substr str (+ 3 j) (- k j 2))
                 );setq
   (set  (read(strcat "bl-" (itoa bl-i))) (substr str 1 j))
   (set (read(substr str 1 j)) (atof sz))
  (setq j nil
 k nil
 sz nil);setq 清零
;**********赋值****
(defun c:rea()
(setq datefile(getfiled "选择钢管杆的信息文件" "C:/Documents and Settings/Administrator/桌面/" "txt" 2))
  (setq ff(open datefile "r"))
  (setq bl-i 1)
(while (setq line (read-line ff))
  (split line bl-i)
  (setq bl-i (+ 1 bl-i))
  );while
  (close ff)
  (clear)
(defun clear()
  (setq i 1)
(while (< i bl-i)
  (setq bl-x  (strcat "bl-" (itoa i)))
  (set (read(read bl-x)) nil);----------------这里,例如bl-1="1d-skj",能不能通过2次的read 把1d-skj=nil呢。
  (setq i (1+ i))
  (setq bl-i nil)
我的思路就是bl-1=“1d-skj” 那么read bl-1=1d-skj 从而令1d-skj=nil
GMT+8, 2025-2-23 11:06 , Processed in 0.185479 second(s), 25 queries , Gzip On.
