- 积分
- 7891
- 明经币
- 个
- 注册时间
- 2009-11-1
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
- ;| TOTALAREA version 4.02 (Gile)
- Set the controls AREABOX, TOTALAREA, AREAEDIT, AREASHOW and AREACONV
- - Block "TotalArea":
- A definition block named "TotalArea" must be present in the drawing collection or
- as file "TotalArea.dwg" in an AutoCAD search path directory.
- This block must contain at least three attributes with "LABEL", "UNIT and "AREA" tags.
- "AREA" will be automatically populate with the sum of the areas of objects linked to it.
- (arc, circle, ellipse, polylines, spline, hatch, region, mpolygon)
- If it contains a fourth attribute with "NOBJ" tag, it will also be
- automatically populate with the number of items linked to the block.
- Format the display of the attribute "AREA":
- It is possible to assign a conversion factor to the value of the attribute.
- This value is managed with a variable (AREACONV) that can be changed with the
- command of the same name.
- The display the number of decimal is managed by a variable too (AREAPREC)
- (vl-load-com)
- (or *acdoc*
- (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))
- ;;; AREABOX (gile)
- ;;; Dialog Box for commands calling
- (defun c:Areabox (/ tmp file what_next dcl_id result)
- (or (getenv "AreaConv") (setenv "AreaConv" "1"))
- (or (getenv "AreaPrec")
- (setenv "AreaPrec" (itoa (getvar "LUPREC")))
- (setq tmp (vl-filename-mktemp "Tmp.dcl")
- file (open tmp "w")
- (write-line
- "AreaBox:dialog{label="总面积";
- :boxed_column{label="命令";:row{
- :button{label="总面积";key="(c:totalarea)";width=16;}
- spacer;:text{label="插入并连接";width= 20;}}
- :row{
- :button{label="面积编辑";key="(c:areaedit)";width=16;}
- spacer;:text{label="增加或移除链接";width= 20;}}
- :row{
- :button{label="面积显示";key="(c:areashow)";width=16;}
- spacer;:text{label="显示链接对象";width= 20;}}}
- :boxed_column{label="系统变量";:row{
- :text{key="ConvValue";width= 20;}
- :button{label="AreaConv";key="areaconv";width=16;}}
- :row{:text{key="PrecValue";width= 20;}
- :button{label="AreaPrec";key="areaprec";width=16;}}}
- spacer;cancel_button;}"
- file
- (close file)
- (setq dcl_id (load_dialog tmp))
- (setq what_next 2)
- (while (>= what_next 2)
- (if (not (new_dialog "AreaBox" dcl_id))
- (exit)
- (set_tile "ConvValue"
- (strcat "AREACONV = " (getenv "AreaConv"))
- (set_tile "PrecValue"
- (strcat "AREAPREC = " (getenv "AreaPrec"))
- (foreach k '("(c:totalarea)"
- "(c:areaedit)"
- "(c:areashow)"
- (action_tile k "(setq result $key) (done_dialog)")
- (action_tile "areaconv" "(done_dialog 3)")
- (action_tile "areaprec" "(done_dialog 4)")
- (action_tile "cancel" "(done_dialog 0)")
- (setq what_next (start_dialog))
- (cond
- ((= what_next 3) (c:areaconv))
- ((= what_next 4) (c:areaprec))
- (unload_dialog dcl_id)
- (vl-file-delete tmp)
- (and result (eval (read result)))
- (princ)
- ;; TotalAreaBox
- ;; TotalArea command dialog box
- (defun TotalAreaBox (/ lbl unt scl lay lst
- tmp file what_next dcl_id data
- result
- (or (setq lbl (vlax-ldata-get "TotalArea" "lbl"))
- (setq lbl (vlax-ldata-put "TotalArea" "lbl" "Total area"))
- (or (setq unt (vlax-ldata-get "TotalArea" "unt"))
- (setq unt (vlax-ldata-put "TotalArea" "unt" "m"))
- (or (setq scl (vlax-ldata-get "TotalArea" "scl"))
- (setq scl (vlax-ldata-put "TotalArea" "scl" 1))
- (while (setq lay (tblnext "LAYER" (not lay)))
- (setq lst (cons (cdr (assoc 2 lay)) lst))
- (setq lst (vl-sort lst '<))
- (setq lay (getvar "CLAYER"))
- (write-line
- :boxed_column{label="属性";
- :row{:text{label="Label";}
- :edit_box{key="lbl";width=24;}}
- :row{:text{label="单位";}
- :edit_box{key="unt";fixed_width=true;}}}
- :row{:text{label="比例";}
- :edit_box{key="scl";fixed_width=true;}}
- :popup_list{label="图层";key="lay";}}
- :boxed_column{label="变量";:row{
- spacer;ok_cancel_help;}"
- file
- (close file)
- (exit)
- (start_list "lay")
- (mapcar 'add_list lst)
- (end_list)
- (set_tile "lbl" lbl)
- (set_tile "unt" unt)
- (set_tile "scl" (rtos scl))
- (set_tile "lay" (itoa (vl-position lay lst)))
- (action_tile "lbl" "(setq lbl $value)")
- (action_tile "unt" "(setq unt $value)")
- (action_tile
- "scl"
- "(if (< 0 (distof $value))
- (setq scl (distof $value))
- (progn (alert "Needs a valid scale.")
- (setq scl (vlax-ldata-get "TotalArea" "scl"))
- (mode_tile "scl" 2)))"
- (action_tile "lay" "(setq lay (nth (atoi $value) lst))")
- (action_tile "help" "(done_dialog 5)")
- (action_tile
- "accept"
- "(setq result (list lbl unt scl lay))
- (vlax-ldata-put "TotalArea" "lbl" lbl)
- (vlax-ldata-put "TotalArea" "unt" unt)
- (vlax-ldata-put "TotalArea" "scl" scl)
- (done_dialog 1)"
- (cond
- ((= what_next 5) (help "TotalArea"))
- result
- ;;; TOTALAREA (gile)
- ;;; Insert "TotalArea" block which "AREA" attribute value equals to
- ;;; the sum of selected objects areas
- (defun c:TotalArea (/ *error* space dz bloc tot ss lst ins scl blk)
- (defun *error* (msg)
- (or (= msg "Function cancelled")
- (princ (strcat "\Error: " msg))
- (setvar "DIMZIN" dz)
- (vla-EndUndoMark *acdoc*)
- (princ)
- (setq Space (if (= (getvar "CVPORT") 1)
- (vla-get-PaperSpace *acdoc*)
- (vla-get-ModelSpace *acdoc*)
- dz (getvar "DIMZIN")
- (if (or
- (gc:GetItem
- (vla-get-Blocks *acdoc*)
- (setq bloc "TotalArea")
- (findfile (setq bloc "TotalArea.dwg"))
- (if (setq data (TotalAreaBox))
- (if
- (ssget
- '((-4 . "<OR")
- (0 . "ARC,CIRCLE,ELLIPSE,LWPOLYLINE,HATCH,MPOLYGON,REGION")
- (-4 . "<AND")
- (0 . "POLYLINE")
- (-4 . "<NOT")
- (-4 . "&")
- (70 . 120)
- (-4 . "NOT>")
- (-4 . "AND>")
- (-4 . "<AND")
- (0 . "SPLINE")
- (-4 . "&")
- (70 . 8)
- (-4 . "AND>")
- (-4 . "OR>")
- (progn
- (setq tot 0.0)
- (vla-StartUndoMark *acdoc*)
- (vlax-for obj (setq ss (vla-get-ActiveSelectionset *acdoc*))
- (setq tot (+ tot (vla-get-Area obj))
- lst (cons obj lst)
- (vla-delete ss)
- (initget 1)
- (setq ins (getpoint "\nSpecify insertion point: ")
- scl (caddr data)
- blk
- (vla-insertBlock
- Space
- (vlax-3d-point (trans ins 1 0))
- bloc
- scl
- scl
- scl
- 0.0
- (vla-put-layer blk (cadddr data))
- (setvar "DIMZIN" (Boole 2 (getvar "DIMZIN") 8))
- (foreach att (vlax-invoke blk 'GetAttributes)
- (cond
- ((= (vla-get-TagString att) "LABEL")
- (vla-put-TextString att (car data))
- ((= (vla-get-TagString att) "UNIT")
- (vla-put-TextString att (cadr data))
- ((= (vla-get-TagString att) "AREA")
- (vla-put-Textstring
- att
- (rtos (/ tot (distof (getenv "areaConv")))
- 2
- (atoi (getenv "AreaPrec"))
- ((= (vla-get-TagString att) "NOBJ")
- (vla-put-TextString att (itoa (length lst)))
- (vlax-ldata-put
- blk
- "TotalArea"
- (mapcar 'vla-get-Handle lst)
- ;; Creating reactor
- (foreach obj lst
- (vlr-object-reactor
- (list obj)
- (vla-get-Handle blk)
- '((:vlr-erased . GC:AREAOBJECTERASED)
- (:vlr-unerased . GC:AREAOBJECTUNERASED)
- (:vlr-objectClosed . GC:AREAOBJECTCLOSED)
- (princ "\n"TotalArea" block can't be found.")
- (princ)
- ;;; AREAEDIT (gile)
- ;;; Add or remove links to "TotalArea" block
- (defun c:AreaEdit (/ *error* lst blk obj elst rea)
- (mapcar (function (lambda (x) (vla-highlight x :vlax-false)))
- lst
- (princ)
- (sssetfirst nil nil)
- (if (setq lst (gc:AreaGet "\nSelect the block to edit: "))
- (progn
- (setq blk (car lst)
- lst (cadr lst)
- (while (setq obj
- (car
- (entsel
- "\nSelect an object to add or remove: "
- (setq elst (entget obj))
- (if (or
- (member (cdr (assoc 0 elst))
- '("ARC" "CIRCLE" "ELLIPSE"
- "LWPOLYLINE" "HATCH" "MPOLYGON"
- "REGION"
- (and (= (cdr (assoc 0 elst)) "POLYLINE")
- (zerop (logand 120 (cdr (assoc 70 elst))))
- (and (= (cdr (assoc 0 elst)) "SPLINE")
- (= 8 (logand 8 (cdr (assoc 70 elst))))
- (if (member (setq obj (vlax-ename->vla-object obj)) lst)
- (progn
- (setq lst (vl-remove obj lst))
- (vla-highlight obj :vlax-false)
- (if (setq rea (gc:GetAreaObjectReactor obj blk))
- (vlr-remove rea)
- (progn
- (setq lst (cons obj lst))
- (vla-highlight obj :vlax-true)
- (list obj)
- (gc:TotalAreaUpd blk lst)
- lst
- (princ)
- ;;; AREASHOW (gile)
- ;;; Highlight the linked objects to the block the cursor is on
- (defun c:AreaShow (/ blk lst)
- (and (setq lst (gc:AreaGet ""))
- (cadr lst)
- (princ)
- ;;; AREACONV (gile)
- ;;; Edit AREACONV sysvar value
- ;;; This sysvar is registered and manages the area unit conversion factor
- ;;; example : 10000 for cm?-> m? 1000000 (or 1e6) for m?-> km?
- (defun c:AreaConv ()
- (while
- (not
- ((lambda (r)
- (or (= r "")
- (< 0 (distof r))
- (setq
- r (getstring
- (strcat "\nEnter a new value for AREACONV <"
- (getenv "AreaConv")
- (princ "\nNeeds a strictly positive number")
- (or (= r "") (setenv "AreaConv" r))
- (princ)
- ;;; AREAPREC (gile)
- ;;; This registered sysvar manages the number of decimal displayed
- (defun c:AreaPrec ()
- (while
- (not
- ((lambda (r)
- (or (= r "")
- (and
- (= 'INT (type (read r)))
- (<= 0 (atoi r))
- (setq
- r (getstring
- (strcat "\nEnter a new value for AREAPREC <"
- (getenv "AreaPrec")
- (or (= r "") (setenv "AreaPrec" r))
- (princ)
- ;;;================== SUB ROUTINES ==================;;;
- ;;; gc:TotalAreaUpd (gile)
- ;;; Update of a "TotalArea" block attributes
- (defun gc:TotalAreaUpd (blk lst / *error* dz hand tot pl new)
- (vl-load-com)
- (princ)
- (setq dz (getvar "DIMZIN"))
- (if lst
- (progn
- (setq tot 0.0)
- (foreach obj lst
- (if obj
- new (cons (vla-get-Handle obj) new)
- (cond
- att
- 2
- (vla-put-TextString att (itoa (length new)))
- (cond
- att
- (rtos 0.0 2 (atoi (getenv "AreaPrec")))
- (vla-put-TextString att "0")
- ;;; gc:AreaGet (gile)
- ;;; Returns a list which countains a "TotalArea" block and all linked objects
- ;;; Linked objects are highlighted while the cursor is on the block
- (defun gc:AreaGet (msg / ss l1 gr ent l2 l3)
- (princ (strcat "\nError: " msg))
- l2
- (princ)
- (princ msg)
- (while (and (setq gr (grread T 4 2)) (= (car gr) 5))
- (if (and (setq ent (nentselp (cadr gr)))
- (or
- (and
- (caddr ent)
- (setq ent (last (last ent)))
- (setq ent (cdr (assoc 330 (entget (car ent)))))
- (if (= (cdr (assoc 2 (entget ent))) "TotalArea")
- (progn
- (setq blk T
- l1 (vlax-ldata-get ent "TotalArea")
- (foreach h l1
- (if (setq obj (gc:HandleToObject h))
- (progn
- (or (member obj l2) (setq l2 (cons obj l2)))
- (progn
- l2
- (setq l2 nil
- blk nil
- (if (and (= (car gr) 3) l2)
- (list (vlax-ename->vla-object ent) l2)
- l2
- ;;; gc:AreaUpdAll
- ;;; Updates all "ToTalArea" block references
- (defun gc:AreaUpdAll (/ ss)
- (if (ssget "_X" '((0 . "INSERT") (2 . "TotalArea")))
- (progn
- (vlax-for blk (setq ss (vla-get-activeSelectionSet *acdoc*))
- (gc:TotalAreaUpd
- blk
- (mapcar 'gc:HandleToObject
- (vlax-ldata-get blk "TotalArea")
- (vla-delete ss)
- ;;; gc:GetAreaObjectReactor
- ;;; Returns the reactor linked to the object
- ;;; Arguments
- ;;; obj : owner object (vla-object)
- ;;; blk : the block linked to object (vla-object)
- ;;; Retour : the reactor or nil
- (defun gc:GetAreaObjectReactor (obj blk / lst rea loop)
- (setq lst (cdr (assoc :VLR-Object-Reactor (vlr-reactors)))
- loop T
- (while (and lst loop)
- (setq rea (car lst)
- lst (cdr lst)
- (if (and
- (equal (vlr-owners rea) (list obj))
- (= (vlr-data rea) (vla-get-Handle blk))
- (setq loop nil)
- (setq rea nil)
- rea
- ;;; gc:GetItem (gile)
- ;;; Returns a vla-object if item exists in the collection
- ;;; Arguments
- ;;; col : the collection (vla-object)
- ;;; name : the item name (string) or its index (integer)
- ;;; Return : the vla-object or nil
- (defun gc:GetItem (col name / obj)
- (vl-catch-all-apply
- (function (lambda () (setq obj (vla-item col name))))
- obj
- ;; gc:HandleToObject (gile)
- ;; Returns the VLA-OBJECT about its handle
- ;;; Argument
- ;;; handle : the object handle
- (defun gc:HandleToObject (handle / obj)
- (function
- (lambda ()
- (setq obj (vla-HandleToObject
- (vla-get-ActiveDocument (vlax-get-acad-object))
- handle
- obj
- ;;;================== CALLBACKS ==================;;;
- (defun GC:AREAOBJECTERASED (own rea lst)
- (vlr-remove rea)
- (defun GC:AREAOBJECTUNERASED (own rea lst)
- (if (setq blk (gc:HandleToObject (vlr-data rea)))
- (vlr-add rea)
- (vlr-remove rea)
- (defun GC:AREAOBJECTCLOSED (own rea lst / blk data)
- (if (setq data (vlax-ldata-get blk "TotalArea"))
- (gc:TotalAreaUpd blk (mapcar 'gc:HandleToObject data))
- (vlr-remove rea)
- ;;;==================== CREATING REACTORS WHILE LOADING ====================;;;
- ((lambda (/ ss obj)
- (foreach r (cdr (assoc :VLR-Object-Reactor (vlr-reactors)))
- (if (member '(:VLR-erased . GC:AREAOBJECTERASED)
- (vlr-reactions r)
- (vlr-remove r)
- (progn
- (vlax-for blk (setq ss (vla-get-ActiveSelectionSet *acdoc*))
- (foreach hand (vlax-ldata-get blk "TotalArea")
- (if (setq obj (gc:HandleToObject hand))
- (list obj)
- (vla-delete ss)
- (princ)
