- (defun C:SEARCHFOR (/ foundfiles folder fn)
- (defun filesearch (fld filename / fld fn found flst lst)
- (cond ((setq flst
- (vl-remove ".." (vl-remove "." (vl-directory-files fld)))
- (setq
- lst (mapcar
- (function (lambda (n)
- (if (= (substr fld (strlen fld) 1) "\")
- (strcat fld n)
- (strcat fld "\" n)
- flst
- (foreach fd lst
- (cond ((vl-file-directory-p fd)
- (filesearch fd filename)
- (T
- (cond ((wcmatch fd filename)
- (setq found fd
- foundfiles
- (cons found foundfiles)
- (princ found)
- (terpri)
- (defun BrowseForFolder (PrmStr / ShlObj Folder FldObj OutVal)
- (vl-load-com)
- (setq
- ShlObj (vla-getInterfaceObject
- (vlax-get-acad-object)
- "Shell.Application"
- Folder (vlax-invoke-method ShlObj 'BrowseForFolder 0 PrmStr 0)
- (vlax-release-object ShlObj)
- (if Folder
- (progn
- (setq FldObj (vlax-get-property Folder 'Self)
- OutVal (vlax-get-property FldObj 'Path)
- (vlax-release-object Folder)
- (vlax-release-object FldObj)
- OutVal
- (setq folder (BrowseForFolder "选择要查找的文件夹: ")
- fn (getstring "\n要查找的文件<*.dwg>: ")
- (if (= folder "")
- (setq folder (getenv "systemDrive"))
- (if (= fn "")
- (setq fn "*.dwg");查询所有的图形文件
- (cond ((and folder (/= fn ""))
- (filesearch folder fn)
- (princ
- (strcat "\n共有" (itoa (length foundfiles)) "文件被查询到")
- (princ)
