查看: 3655|回复: 9
[基础] 读写二进制研究
发表于 2009-12-28 15:17:00 | 显示全部楼层 |阅读模式
;Subject:binary conversion to text by lisp 二进制文件转文本
;Writen:nonsmall(不死猫)
;Date:2009 10 18
;All Rights Reserved 版权所有 nonsmall(不死猫)
;Contact: QQ:43797405 Email:nonsmall@163.com
(defun binaryToText(FileName / ADODB.Stream)
 (Setq ADODB.Stream (Vlax-Get-Or-Create-Object "ADODB.Stream" ))
 (Vlax-Put-Property ADODB.Stream 'Type 1 )
 (Vlax-Invoke ADODB.Stream 'Open )
 (Vlax-Invoke-Method ADODB.Stream 'LoadFromFile FileName )
 (Vlax-Put-Property ADODB.Stream 'Position 0 )
 (Vlax-Invoke-Method ADODB.Stream 'Write (car (list (Vlax-Invoke-Method ADODB.Stream 'Read (Vlax-Get ADODB.Stream 'Size )) (Vlax-Put-Property ADODB.Stream 'Position 0 ))))
 (Vlax-Put-Property ADODB.Stream 'Type 2 )
 (Vlax-Put-Property ADODB.Stream 'CharSet "us-ascii" )
 (Vlax-Invoke ADODB.Stream 'ReadText)
 ;(vlax-release-object ADODB.Stream)
(defun _WriteStream ( path text mode / fso stream file result )
    ;;  Return the file size if the file is successfully written
    ;;  to, otherwise nil. Will write all ascii chars to file
    ;;  including nulls. If the caller wants to pass a list of
    ;;  byte values to the function just call it like so:
    ;;      (_WriteStream
    ;;          path
    ;;          (vl-list->string '(87 111 111 116 33))
    ;;          mode
    ;;  Arguments:
    ;;      path  <duh>
    ;;      text  <duh>
    ;;      mode  "a" to create/append,
    ;;            "w" to create/overwrite (default)
    (setq mode (if (member mode '("a" "A")) "a" "w"))
    (vl-catch-all-apply
       '(lambda ( / format )
            (setq fso (vlax-create-object "Scripting.FileSystemObject"))
            (cond
                (   (or (null (findfile path)) (eq "w" mode))
                    (setq stream
                        (vlax-invoke
                            fso
                           'CreateTextFile
                            path
                           -1 ;; 0 (false) = don't overwrite , -1 (true) = overwrite
                            0 ;; 0 (false) = ascii, -1 (true) = unicode
                    (setq file (vlax-invoke fso 'GetFile path))
                (   (setq file (vlax-invoke fso 'GetFile path))
                    (setq stream
                        (vlax-invoke
                            file
                           'OpenAsTextStream
                            8 ;; 1 = read, 2 = write, 8 = append
                            0 ;; 0 = ascii, -1 = unicode, -2 system default
            (vlax-invoke stream 'Write text)
            (vlax-invoke stream 'Close)
            (setq result (vlax-get file 'Size))
    (if file (vlax-release-object file))
    (if stream (vlax-release-object stream))
    (if fso (vlax-release-object fso))
    result
测试:(_writestream "d:\\jmj.sld" (vl-list->string (vl-string->list (binarytotext "d:\\bsph.sld"))) "w")
生产的JMJ.SLD的值和原来的BSPH.SLD的值是一样的,文件大小也相等!
但是预览效果也不同,为什么
bsph.SLD是这样的
而JMJ.SLD是这样的
发表于 2009-12-30 00:56:00 | 显示全部楼层
你所用的程序在实际使用时是有问题的,这有老外做的读写二进制文件工具,很好用;
加载后(注意07,08用ReadBin17.arx,05,06用ReadBin16.arx),用函数binget,binput即可。
以下为示例:
  1. ;读写幻灯片文件
  2. (defun c:test2 ( / )
  3. (setq a (binget "d:\\GB56.sld" ));读取二进制文件
  4. (binput "d:\\GB56-1.sld" a );写二进制文件
  5. )
  6. (defun c:test3 ( / )
  7. (binput "c:\\McCoy2.dwg" (binget "c:\\McCoy.dwg" ) )
  8. )
发表于 2009-12-28 22:44:00 | 显示全部楼层
应该还有一个“textToBinary”
 楼主| 发表于 2009-12-28 23:09:00 | 显示全部楼层
楼上能留下QQ吗?想进一步请教
发表于 2009-12-29 10:20:00 | 显示全部楼层
我也是花了三天时间,硬是没有找到正确的解决方法。
问我也无解。
发表于 2010-7-6 11:42:00 | 显示全部楼层
非常好,多谢
发表于 2012-10-27 17:38:18 | 显示全部楼层
经试用,xianaihua 提供的方法的确好用!
发表于 2018-5-7 14:49:42 | 显示全部楼层
5楼的方法很好用,唯一的缺点就是.arx也没办法一直打包到vlx中,用在别的电脑上需先加载ReadBin17.arx
yxp
办法有很多  发表于 2018-5-14 21:35
发表于 2021-10-4 22:38:03 | 显示全部楼层
学习一下怎么实现的
GMT+8, 2025-5-16 14:53 , Processed in 0.186914 second(s), 27 queries , Gzip On.
