- 积分
- 12423
- 明经币
- 个
- 注册时间
- 2005-2-6
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
测试代码:
[CommandMethod("cc")]
public void cc()
Circle cir = new Circle(new Point3d(), Vector3d.ZAxis, 10.0);
var v = Drag.StartDrag("\n开始Jig托动:",
rst => { cir.Center = rst.Point; rst.Draw(cir); }
if (v.Status != PromptStatus.OK)
return;
v = Drag.StartDrag(
new JigPromptDistanceOptions
("\n指定半径:"),
rst =>
cir.Radius = rst.Dist == 0.0 ? 1e-6 : rst.Dist;
rst.Draw(cir);
if (v.Status == PromptStatus.OK)
CAD.AppendEntity(cir);
封装成函数的jig~调用是不是很方便呢???
CAD.AppendEntity()函数请自写!(加入Entity到当前图面)删除这行也能单独测试Jig
下面函数式Jig模块代码: - #define 测试中
- using System;
- using Autodesk.AutoCAD.ApplicationServices;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.Geometry;
- using Autodesk.AutoCAD.GraphicsInterface;
- using Autodesk.AutoCAD.Runtime;
- using System.Windows.Forms;
- using System.Drawing;
- namespace FsxmAcad
- /// <summary>
- /// 封装简化Jig操作,函数式实现DrawJig
- /// </summary>
- public class Drag : DrawJig
- protected Drag() { }
- #region =====封装Jig方法=====
- protected override bool WorldDraw(WorldDraw draw)
- _callBack(new Result(_rst, draw));
- return true;
- protected override SamplerStatus Sampler(JigPrompts prompts)
- return _acquireMod(prompts);
- #endregion
- #region 定义各种Jig模式
- static PromptResult _rst;
- delegate SamplerStatus AcquireMod(JigPrompts prompts);
- //AcquirePoint
- static Point3d _point3d;
- static JigPromptPointOptions _PointOptions;
- static SamplerStatus GetPoint(JigPrompts prompts)
- PromptPointResult rst = prompts.AcquirePoint(_PointOptions);
- _rst = rst;
- if (rst.Value != _point3d)
- _point3d = rst.Value;
- return SamplerStatus.OK;
- else
- return SamplerStatus.NoChange;
- //AcquireDistance
- static Double _double;
- static JigPromptDistanceOptions _DistanceOptions;
- static SamplerStatus GetDistance(JigPrompts prompts)
- var rst = prompts.AcquireDistance(_DistanceOptions);
- _rst = rst;
- if (rst.Value != _double)
- _double = rst.Value;
- else
- //AcquireAngle
- static JigPromptAngleOptions _AngleOptions;
- static SamplerStatus GetAngle(JigPrompts prompts)
- var rst = prompts.AcquireAngle(_AngleOptions);
- _rst = rst;
- else
- //AcquireString
- static Point _cur;
- static JigPromptStringOptions _StringOptions;
- static SamplerStatus GetString(JigPrompts prompts)
- var rst = prompts.AcquireString(_StringOptions);
- _rst = rst;
- var cur = Form.MousePosition;
- if (Form.MousePosition != _cur)
- _cur = cur;
- else
- #endregion
- /// <summary>回调函数之参数</summary>
- public class Result
- PromptResult rst;
- WorldDraw draw;
- internal Result(PromptResult promptResult, WorldDraw worldDraw)
- rst = promptResult;
- draw = worldDraw;
- /// <summary>原始返回值</summary>
- public PromptResult PromptResult
- get { return rst; }
- /// <summary>绘图对象</summary>
- public Geometry Geometry
- get { return draw.Geometry; }
- /// <summary>绘图方法</summary>
- public void Draw(Drawable entity)
- if (draw != null)
- draw.Geometry.Draw(entity);
- /// <summary>GetPoint模式下的当前点位置</summary>
- public Point3d Point
- get { return _point3d; }
- /// <summary>GetDist模式下的当前距离</summary>
- public Double Dist
- get { return _double; }
- /// <summary>GetAngle模式下的当前角度</summary>
- public Double Angle
- /// <summary>返回值指示</summary>
- public PromptStatus Status
- get { return rst.Status; }
- /// <summary>返回的字串or关键字</summary>
- public string String
- get { return rst.StringResult; }
- static Action<Result> _callBack;
- static AcquireMod _acquireMod;
- /// <summary>简便快捷执行Jig托动</summary>
- /// <param name="options">选项</param>
- /// <param name="callFun">回调函数</param>
- public static PromptResult StartDrag(JigPromptOptions options, Action<Result> callFun)
- if (options is JigPromptPointOptions)
- _PointOptions = options as JigPromptPointOptions;
- _acquireMod = GetPoint;
- else if (options is JigPromptDistanceOptions)
- _DistanceOptions = options as JigPromptDistanceOptions;
- _acquireMod = GetDistance;
- else if (options is JigPromptAngleOptions)
- _AngleOptions = options as JigPromptAngleOptions;
- _acquireMod = GetAngle;
- else if (options is JigPromptStringOptions)
- _StringOptions = options as JigPromptStringOptions;
- _acquireMod = GetString;
- _callBack = callFun;
- Autodesk.AutoCAD.ApplicationServices.Application.
- DocumentManager.MdiActiveDocument.Editor.Drag(new Drag());
- _callBack(new Result(_rst, null));
- return _rst;
- /// <summary>简便快捷执行Jig托动[Point模式]</summary>
- /// <param name="msg">提示信息</param>
- /// <param name="kwd">关键字</param>
- public static PromptResult StartDrag(string msg, string kwd, Action<Result> callFun)
- return StartDrag(new JigPromptPointOptions(msg, kwd), callFun);
- public static PromptResult StartDrag(string msg, Action<Result> callFun)
- return StartDrag(new JigPromptPointOptions(msg), callFun);
- #if 测试中
- public class test
- [CommandMethod("tt")]
- public void tt()
- Circle cir = new Circle(new Point3d(), Vector3d.ZAxis, 10.0);
- var v = Drag.StartDrag("\n指定圆中心点:",
- rst => { cir.Center = rst.Point; rst.Draw(cir); }
- if (v.Status != PromptStatus.OK)
- return;
- v = Drag.StartDrag(
- new JigPromptDistanceOptions("\n指定圆半径:"),
- rst =>
- cir.Radius = rst.Dist == 0.0 ? 1e-6 : rst.Dist;
- rst.Draw(cir);
- if (v.Status == PromptStatus.OK)
- CAD.AppendEntity(cir);
- #endif
| 参与人数 1 | 威望 +1 |
明经币 +2 |
金钱 +20 |
贡献 +5 |
激情 +5 |
收起
理由
雪山飞狐_lzh
| + 1 |
+ 2 |
+ 20 |
+ 5 |
+ 5 |
【精华】好思路 |
