;;vla (defun c:tt1 (/ lst) (vlax-for lay (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq lst (cons (vla-get-name lay) lst)) ) ) ;;autoLisp (defun c:tt2 (/ lay lst) (while (setq lay (tblnext "layer" (not lay))) (setq lst (cons (cdr (assoc 2 lay)) lst)) ) lst ) |
