查看: 2343|回复: 2
测试鼠标双击问题
发表于 2010-1-19 00:51:00 | 显示全部楼层 |阅读模式
我画了任意两条线A、B,其中A加到那“SS”里面,双击的B时还是会响应A的双击事件,应该怎么去控制只有双击A的时候才响应双击事件?请高手们指点一下啊!!!
(defun c:asdf ( / ss )
  (setq ss (vlax-ename->vla-object (car (entsel))))
  (vlr-mouse-reactor (list ss) '((:vlr-beginDoubleClick . fdsa)))
(defun fdsa ( a b )
  (princ "\n")
  (princ (vla-get-Length (nth 0 (vlr-data a))))
  (princ "\n")
  (princ b)
  (princ "\n")
  (princ "yes")
发表于 2010-1-19 08:38:00 | 显示全部楼层
因为你的程序中没有判断当前双击的对象是不是你所附着的对象,所以不管你双击谁都会有信息的,可以这样改一下:
(defun c:asdf (/ ss)
  (vlr-mouse-reactor
    (list ss)
(defun fdsa (a b)
  (setq en (nentselp (car b)))
  (if en
      (if (> (length en) 2)
   (setq en (last (last en)))
   (setq en (car en))
      (if (eq (vlax-vla-object->ename (nth 0 (vlr-data a))) en)
   (princ "\n")
   (princ "\n")
   (princ b)
   (princ "\n")
   (princ "yes")
 (princ "\n所选的直线不是附着的直线!")
  (princ "\n")
 楼主| 发表于 2010-1-20 00:22:00 | 显示全部楼层
谢谢英雄无敌
GMT+8, 2025-2-22 18:42 , Processed in 0.140486 second(s), 25 queries , Gzip On.
