查看: 1814|回复: 1
随机获取表中的对象
发表于 2010-1-20 10:28:00 | 显示全部楼层 |阅读模式
调用此函数可以模拟掷毂子和洗扑克牌
(defun randGetObj (alist / int int0 int1 second n item)
  (if (not (listp alist))
      (princ "\n参数类型错误!")
      (quit)
  (if (or (< (length alist) 2) (> (length alist) 60000))
      (princ "\n参数表中的元素太多或太少了")
      (quit)
  (setq int (length alist))
  (setq int0 (fix (/ 60000 int))
 int0 (* int0 int)
 int0 (1- int0)
  (setq second (read (menucmd "M=$(edtime,$(getvar,date),ss.MSEC)"))
 int1   (* second 1000)
 n      1
  (while (and (< n 10) (< int0 int1))
   n  (1+ n)
  (if (= n 10)
    (setq int1 0)
  (setq item (fix (rem int1 int)))
  (nth item alist)
发表于 2010-1-20 15:57:00 | 显示全部楼层
说白了就是带一组seed的随机函数
GMT+8, 2025-2-22 18:27 , Processed in 0.175993 second(s), 26 queries , Gzip On.
