查看: 2365|回复: 2
[求助]急!字符串的分割问题!
发表于 2010-1-27 13:59:00 | 显示全部楼层 |阅读模式
如果我又这么一个字符串"0001,test,测试,テスト",怎样才能根据逗号分隔符找出我需要的字符串。
例如如何找出"test"。
不要用substr这个操作符,因为这样的话,我得指定固定的长度和起始位置了。
大家帮帮忙,先谢谢了!
发表于 2010-1-27 14:37:00 | 显示全部楼层
  ;;  parser by CAB
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
_$ (sparser "12,3,4,,5,6," ",")
("12" "3" "4" "" "5" "6" "")
_$ (vl-remove "" (sphraser "12,3,4,,5,6," ","))
("12" "3" "4" "5" "6")
info:
Http://discussion.autodesk.com/forums/thread.jspa?threadID=759125&tstart=0
 楼主| 发表于 2010-1-27 15:36:00 | 显示全部楼层
Andyhon发表于2010-1-27 14:37:00  ;;++++++++++++++++++  ;;  parser by CAB    ;;++++++++++++++++++  (defun sparser (str delim / ptr lst)    (while (setq ptr (vl-string
谢谢了!
GMT+8, 2025-4-18 23:18 , Processed in 0.156990 second(s), 25 queries , Gzip On.
